Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Drivetrain Problems
Old 10-19-2006, 04:41 PM
tank tank is offline
Send a message via Yahoo to tank
Cool steering problems
Steering wheel is hard to turn at times. When at a stop. I replaced steering pump and it did not help. Any input on this problem? T:whistle: hanks
Old 10-19-2006, 04:55 PM
Logan Logan is offline
The Fat Mod
Did you make sure that everything was good and tight?
Old 10-19-2006, 04:56 PM
The Fat Mod
Oh and...
to POWERSTROKE.ORG
Old 10-19-2006, 05:03 PM
Maintain Maintain is offline
13.0 @ 102
Send a message via AIM to Maintain
Pretty common problem, I've researched it thinking something was majorly wrong with my truck BUT some trucks had it off the dealership lot. Mine does it when I first start it in the cold mornings when not moving. I just make sure I move before I turn the wheel! I choose to just live with it, since it doesn't affect me really.
Marc will be on and he can probably help you.
Old 10-19-2006, 05:06 PM
payne5757 payne5757 is offline
If you are on the brakes hard, the geometry of these spindles in respect to where the ball joints mount makes it hard to turn the wheels while sitting still or moving really slowly. Instead of the tires just being stationary and twisting when u turn the wheel, they actually roll forward and back a lil when u turn the wheel and if you arent moving and the brakes are applied, it opposes the turning of the tire.
I had to figure this out on my own, as I too wondered why it was difficult but realised the brakes were doing it after a lil trial and error testing. If it is still hard and your not on the brake(ie in park) then its something else. Just my .02
Old 10-21-2006, 08:57 AM
steering problems
my next step is to replace the steering box.It does not matter if I have my foot on the brake or not and this steering problem happens about 75% of the time.
Old 10-21-2006, 10:12 AM
Brian Brian is offline
is there alot of play in the sterring wheel?
Old 10-21-2006, 10:50 AM
no play in the wheel.
Old 10-21-2006, 11:24 AM
jngreen jngreen is offline
redneck country boy
Send a message via AIM to jngreen
it is a pretty common problem with the extra weight of the diesel engine, but it seems your's is more extreme. I don't believe that I could just live with it either if it happens 75% of the time.
hopefully you find out what the problem is.
I can tell you this much, mine never acted that bad when I had my 39.5 Swampers on my truck.
Old 12-17-2006, 12:36 PM
ipz2222 ipz2222 is offline
I hope you find out what it is. My 01 4x4 does it also. It acts like it switches from power to manual steering. Preston
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
