Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Problem Forum > 7.3 Drivetrain Problems
Old 02-14-2008, 11:05 PM
Dallas4x4 Dallas4x4 is offline
rear Drive shaft Carrier bearing replacemnt
How would i go about replacing mine. Mine doesnt keep the drive shaft spinning true. I can shake the drive shaft in the carrier.
Its that Carrier the holds the 1st rear drive shaft up. I need to replace that bearing on there. How do they come off or install?
(not a pic from my truck, used to show what im taking about)
Old 02-14-2008, 11:33 PM
lilredpowerstroke lilredpowerstroke is offline
Ballin' on a budget
You have to take the big nut off.
what big nut?
Old 02-14-2008, 11:40 PM
pinion nut?
Old 02-15-2008, 12:21 AM
Ballin' on a budget
I forgot your truck was an OBS. Once you remove the metal part you can cut the rubber part off. It is normally pressed on. It is a PITA to get the new one on. The dealer will charge out the azz. If you have a driveshaft place near you they can do it cheaper than the dealer.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
