Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Drivetrain Problems
Old 09-07-2006, 10:58 AM
bssharp79 bssharp79 is offline
Got a Vibration Problem
I have a 99 F-350 4x4 and here lately when I drive it I get a wicked vibration that comes from the front end. It generally only vibrates at 50-65 MPH but its such a hard vibration that it makes the steering wheel bounce. The pickup has 209,000 miles but I notice that when I start hitting the brakes it tends to pull to the left which seems to be where alot of the vibration is coming from. I know I didnt throw a wheel weight because I still see all of them and keep track of how many and what size are on each wheel. I am guessing that since the brakes pull it might be a rotor warped or something like that any suggestions would help.
Old 09-07-2006, 03:40 PM
Log Dog Log Dog is offline
<b>Premium Member</b>
Sounds like bad ball joints.
Old 09-07-2006, 04:04 PM
mschn99 mschn99 is offline
Banished
it almost sounds to me like you might have a bad tire. If the plies seperate, you will get just what you describe. I would rotate your tires and see if putting that tire in the back makes the vibration from the rear....
Old 09-13-2006, 08:57 AM
Ok Well I rotated the tires front to back and back to front still there. And now its seems to have gotten worse. I came back from the farm this morning and when I looked in the wheel well I got a face full of very hot heat wave and what smelled like Brake pads and fluid burning. So would it be safe to say that it is a rotor problem.
Old 09-13-2006, 11:34 AM
Banished
is there a lot of brake dust on that tire as well?? sticking caliper would be my guess cause you should not be able to feel a rotor without the brakes applied....
Old 09-13-2006, 11:53 AM
CHenry CHenry is offline
Sooner Powerstroker
yep, i would rebuild your caliper or buy new ones. Do a brake jobs and get new rotors if those are old and worn at all. Brakes are one thing i take very seriously and try not to cut any corners on.
Just my opinion.
Old 09-15-2006, 06:29 AM
Its hard to tell if there would be brake dust on there we have gotten about 3 inches of rain in the last 3 days so I got Mud caked in the wheels and all over but I will certainly take the Calipers and go from there I appreciate all your help
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
