- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Brake light
I recently replace my master cylinder, back brake calipers and pads. Bled all lines, started in back first. the problem is my brake light will not go out. My brakes are working fine though. I also checked the parking brake line and it is loose. Any help would be appreciated
| Sponsored Links |
There are two things that normally cause that light to illuminate. One is the parking brake pedal switch. The second is low brake fluid in the master cylinder. Because you just changed the master, the second is the most likely cause. Check your fluid level and make sure the electrical connector on the side of the master cylinder is plugged in. hope this helps |
Do you mean the brake light on the dash or the brake lights in the rear?? Preston
| Sponsored Links |
