Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Drivetrain Problems
Old 02-18-2006, 02:53 PM
Green Horn Green Horn is offline
Question Vibration at 50mph & higher
Hopefully someone can help. I just bought a 2001 F-350 that has 122,000 miles on a 7.3. I get a vibration when I get to speeds of 50mph or higher and it you really only notice it when you are the driver. The passenger side you really don't feel it. Any ideas what might cause this would be greatly appreciated.
Old 02-18-2006, 03:20 PM
mschn99 mschn99 is offline
Banished
if its a driveline vibration it is more than likely unbalanced tires, there are some other things it could be, but this is the most common. if its an engine vibration.....give a few more details....like does throttle position affect it and is there a noise associated with it????Marc
Old 02-18-2006, 03:29 PM
Banished
Old 03-15-2006, 04:15 PM
Well after replacing U-joints, rotors, brake pads, and having my tires balanced I replaced the carrier bearing and it took about 95% of the vibration out.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
