| 6.9L IDI Diesels Technical discussion of topics related to vehicles powered by the 6.9 Liter In-Direct Injection Navistar engines. |
fuel problems
i have an 86 6.9 and it has ran great for me
today it started idling rough and when i drive it would be a dog and then crank way up then it would idle fine and then go back to choppy idle i think it may be the fuel pump and/or the fuel lines and filter anyone know what if might be |
Check that fuel pressure!!
how?
i was just gunna put a new fuel line on since the one the previous owner put on is all messed up and since i was gunna do that i was gunna put on a new fuel pump since theyre only $30 Last edited by SCUFFY828; 05-19-2009 at 05:27 AM. |
IIRC on the 6.9 there is a place to put a fitting in the valley of the motor on the driver side attached to the fuel lines coming into the bowl.
shouldnt i just plan on changing the pump since its only $30 and its prolly the original pump
first rule of any repair is to do proper diagnosis before replacing any part , make sure you have good fuel pressure 5-8 lbs to be exact will run the truck fine , no need to buy parts that arent needed
For $30 if its was the original I would replace it anyway!
why replace a part there may be nothing wrong with , 30 dollars is 30 dollars
doesnt the 6.9 have a fuel bowl similar to the 7.3? same basic setup right?
I know but I just tend to replace stuff when it is really old or has a lot of miles on it. Too many times of being stranded because something suddenly and inexplicably broke or gave out!
