more bad luck - Ford Powerstroke Diesel Forum
6.9L IDI Diesels Technical discussion of topics related to vehicles powered by the 6.9 Liter In-Direct Injection Navistar engines.
post #1 of 16 Old 12-15-2008, 07:44 AM Thread Starter
more bad luck
i was driving my 6.9 and everything was goin good, then it started smoking a lil and i slowed down to stop and it started smoking alot of white. i drove in the driveway and shut it off, popped the hood and the overflow reservor was boilng, so i started it up again and let it idle to cool down, i went in the barn and came back out 5 min later and it was still running and smoking some but the coolant hose on the bottom of the radiator broke and the coolant was going everywhere, so i pulled it off and am going to put a new one on. does anyone have an idea what went wrong
thanks
dieselfuelonly is offline
post #2 of 16 Old 12-15-2008, 12:06 PM Thread Starter
post #3 of 16 Old 12-15-2008, 12:08 PM
age my 94 did that not to long ago
sevenpointthree is offline
post #4 of 16 Old 12-15-2008, 12:25 PM
Rob
Rob's Avatar
Quoted: 2 Post(s)
little bit of an overheat issue. is your thermostat good, it may be stuck closed or jsut partially closed, not allowing the coolant to flow properly creating an overtemp. just throwin this out there. i may be way off!
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #5 of 16 Old 12-15-2008, 08:24 PM Thread Starter
was it the head gasket
post #6 of 16 Old 12-15-2008, 08:24 PM Thread Starter
i think it mite be the headgasket, but i was gunna put on a new radiator hose and thermostat and see what heppens then
post #7 of 16 Old 12-17-2008, 12:14 PM Thread Starter
what would happen if i used my truck to plow with a bad headgasket
post #8 of 16 Old 12-17-2008, 03:19 PM Thread Starter
post #9 of 16 Old 12-19-2008, 02:21 PM Thread Starter
some1 must of had this prob b4
i heard it was common for headgaskets on 6.9's
post #10 of 16 Old 12-20-2008, 07:51 AM Thread Starter
anyone? some1's gotta have a 6.9 that had probs wit it before
