brake and signal lights just stoped working - Ford Powerstroke Diesel Forum
6.9L IDI Diesels Technical discussion of topics related to vehicles powered by the 6.9 Liter In-Direct Injection Navistar engines.
post #1 of 8 Old 03-24-2008, 09:05 PM Thread Starter
hi my trusty 87 brake and signal lights just stoped working fuse isnt blown , cant figure out what it is . any ideas... please
i was towing while this happened
surclay is offline
post #2 of 8 Old 03-24-2008, 09:09 PM
Peppy's Avatar
hzard switch is either stuck slightly or burnt all your signals and brake lights go through this switch
Peppy is offline
post #3 of 8 Old 03-24-2008, 09:09 PM
Check the connections in the rear.
2005F250 is offline
post #4 of 8 Old 03-30-2008, 09:23 AM Thread Starter
no juice to the fuse pannel
well i checked the fuse pannel under the stering wheel and no power to the fuses any sugestions???
surclay is offline
post #5 of 8 Old 03-31-2008, 07:39 AM
dumb question.....did you turn on the key before you checked the panel?
nohairracing is offline
post #6 of 8 Old 03-31-2008, 11:38 AM Thread Starter
theres never a dumb question, thanks did and found that the main colum wire harness became loose because the hook that holds it wasnt working , i should of put it together because my cruise control was also not working which i failed to mention
case closed thanks guys
surclay is offline
post #7 of 8 Old 03-31-2008, 11:53 AM
Chiller's Avatar
I have the same problem so was it the hazard switch? because i put the hazards on they never went on then i looked out the front window and saw my flashers flashing turned them off and now i have the same problem
2005 F350 4x4 CC LB Lariat
Engine: Puking ModIntake, Innovative SCT Tuned, Straight Pipe, Zoodad, DIY CCV.
Exterior: 8inch Rize 4Link, traction bars, Deaver Leafs, Raceline Rims, 37inch Toyos M/Ts, Leer Cap, Bushwacker Pocket Flares, Tints, Lights and little stuff
Interior: Isspro Gauges, Leds bulbs , Livewire, Overhead DVD, Aftermarket alarm/remote start
Chiller is offline
post #8 of 8 Old 04-01-2008, 06:47 AM Thread Starter
i think it was the main conection under the stering coulm the switch that you disconect to take out the signals, usaly the have a lock so they dont get disconected and mine was broke...
surclay is offline
