| 6.9L IDI Diesels Technical discussion of topics related to vehicles powered by the 6.9 Liter In-Direct Injection Navistar engines. |
Have a 6.9, don't know what year, in a 93 truck. Bought it a couple of days ago, drove for 2hrs at 55 to 60mph, then boom, no power, died, won't restart. Looked at the belts, fuel, witres, everything LOOKS good, but I don't know. First 6.9 PO said he turned up the pump, don't know if he knew what he as doing. Can Injector Pumps be turned up to the point of self distructing? Mine looked like holy heck, so I bought a new one. Haven't reinstalled it yet. Truck did smoke when the throttle was used hard, but I tried to avoid this. Black smoke. Otherwise, no smoke at all. Does need new low plugs. Need ideas fast, thanks yall. How do you do a compression test? Pull the glow plugs or the injectors? What pressure should Ibe looking for? Thanks again!
First off you can turn the pumps up and yes they can fail on them. The black smoke means the truck is running good and pulling hard (sorda) we like it cause well it looks cool. Now to repair. You need to put it back together and see what kinda fuel pressure you have.
Fuel Pressure
Before I dismantled it, I checked fuel flow, made sure I was getting fuel past the filter by pushing in on the schrader valve, good. Loosened supply line at the IP, turned over, got fuel. Loosened up injector lines at heads, no fuel. Hoping it's the pump. What brand of fuel filter is recommended? I've used WIX on my PSD for years, any good luck with other brands? Thanks for the help.
I am sure someone will be able to help out here.
cbmind, same problem
I've been working on mine ('86 F250, 6.9) since before Christmas.
At first, thought hard starting was air in the lines (it eventually fired up after a lot of cranking, but that deteriorated to 'no-start' status after a month or so) - now, I've bled lines everywhere, replaced the lift or transfer pump that sits low in the right side block before the fuel filter thinking pressure to the injector pump might be too low to prime it (or some such), all to no avail. Currently, there's fuel at the injector pump supply or intake port, and like you indicate, nothing at the injectors while cranking with the connections cracked. I'm working alone and don't want to chance unbolting the injector pump (just had the darn thing rebuilt less than 50K ago). But, that may be the only option. Last time, I lost the injector pump timing because I couldn't get a perfect match-up for the pump shaft gear with crankshaft gears. Got lucky and limped to a diesle garage where they fixed the timing. Ran perfect for a while. Then this. I've been told I can remove the pump at some 3-bolt plate and leave all the timing gears and housing in place, but I'm not sure I understand how that preserves the timing. As an easier fix, I have heard recently that the whole thing is due to some sort of fuel cut-off solenoid I assume is attached to the injector pump which is stuck in the 'cut-off' position (like when you turn off the ignition key). That would explain the symptoms no fuel to the injector symptom. If you figure out how to check for a bad solenoid or even what it looks like, I'd appreciate any tips. I'll look at mine this afternoon. |
Cbmind, same problem update
Just got it running - good as ever. It was the fuel cut-off solenoid. The electrical contact was corroded and I squirted some WD-40 on the shaft that moves back and forth.
I may go back in if I have time to see just how the marginal solenoid (it's on the top, right (if sitting in the driver's seat) of the injector pump with a two-strand wire attached, really was. Seems as if all it has to lose is a very small, maybe 1/16" of movement to permit fuel to be cut-off when the ignition is on. The pump thinks you've turned off the ignition and is disabled from delivering to the injectors. It may well be a lot more involved than that, but if I'd known of that factor, I'd have checked before struggling through the lift pump replacement - a real knuckle buster, grinding down open-end wrenches for clearance, and lying on the cold ground for extended intervals. What I can't quite figure is why the solenoid is in play at all when you step on the accelerator while cranking the engine to start. Seems to me that alone would rotate the cut-off ear and shaft away from the 'closed' position just like the solenoid should. Anyway, I thought it would be worth letting you know - I nearly replace the injector pump as a last resort and probably would still have had the problem. |
Thanks for the help BUT...wiring at IP
Thanks for all the help guys, finally got my parts in last week and installed today. However, I have a problem...I did not remove the Injector Pump a couple of weeks ago, afriend of mine did it for me. He;s unavailable to install the new one or be here for guidance, so I installed it myself. No problem. The problem I do have is witch connector goes where and how do I tell what's what? No wires are accurately labeled, harness has been butchered beyond belief, etc. I know witch connector is which on the pump itself, but do not know how tell which plug goes to what. Any tips would be greatly appreciated. Thanks!
