5-speed?? - Ford Powerstroke Diesel Forum
6.9L IDI Diesels Technical discussion of topics related to vehicles powered by the 6.9 Liter In-Direct Injection Navistar engines.
Old 08-08-2007, 09:49 PM
5-speed??
What 5-Speed Transmission can I put on my 6.9? It's begging for something other than the the 4-speed that's on it.
Thanks!
Old 08-14-2007, 10:45 PM
Anyone? Or is there another forum for IDI Diesels?
Old 08-14-2007, 10:54 PM
im fat and ugly
no this is the right place buddy
Old 08-14-2007, 11:16 PM
A zf out of a 87-94 with a 7.3 engine you'll need the floor pan and crossmember plus all the clutch hydraulics. or you could buy my 92 with an automatic od for $2k
Old 08-14-2007, 11:25 PM
When you say Floor Pan, are you talking Cab? or just the piece where the Shifter comes through?
Old 08-14-2007, 11:37 PM
the piece of sheetmetal in the floor unbolts the 5sp needs more room try oilburners.net
Old 08-20-2007, 09:29 PM
no you dont need anouther floor pan and you can use the same hyd clutch masster and slave cylinder that you already have. I have done thios swap twice and it is easy. you will have to get a clutch for the five speed cause the input shaft is bigger than the four speed. the cross member must be moved back bot you can drill new holes for the bolts. The time and money are well worth it. I was up in the high 21mpg on my 86 with the banks turbo that I had on it. if you have any questions just email me at tjhamberg@hotmail.com
