Glowplugs not working - Ford Powerstroke Diesel Forum
6.9L IDI Diesels Technical discussion of topics related to vehicles powered by the 6.9 Liter In-Direct Injection Navistar engines.
Old 09-12-2010, 08:47 PM
When i turn the key on, the wait to start light does not come on and there is no clicking like you normally hear... nothing is happening.. and of corse it won't start now without a little ether.. any help?
Old 09-12-2010, 09:31 PM
drives a ranger
Send a message via AIM to kanuck15
check the 22 fuse under the hood. Also check the solenoid itself it might be burnt out. plus maybe the wires might be bad
Old 09-14-2010, 09:44 PM
there is no fusebox under the hood on this... any help
Old 09-14-2010, 10:45 PM
Powered by Deez Nuts
it does crank...right?
get a volt meter and see if power still goes to the relay.
Old 09-15-2010, 06:16 AM
ya its a runner, just have to give it a little shot of starting fluid... also the block heater is not pluged in.. where does that plug into?
Old 09-15-2010, 10:43 AM
DO NOT USE EITHER, you will pop the pre-chambers, your glow plug controller is probably bad, try jumping the glow plug relay on the passenger side front fender, see if that helps
Old 09-15-2010, 10:55 AM
Shaking the Bush Boss
yea, if its a 6.9 idi motor... glow plug controller would be my uneducated guess! NO EITHER...If need be, alittle gas on a rag in th eair cleaner will work
Old 09-15-2010, 09:39 PM
how do you go by jumping that relay.. is that the deal under the metel cover with 2 fuse's and 2 electric deals? i am just trying to sell this truck for a friend.. trying to get stuff working to get more $$.. he has been using starting fluid for 2 years... and the block heater is not pluged in. it hangs down on the right side of block..
Old 09-23-2010, 07:09 AM
Everybody is so anti ether. If used wisely, in emergencies, it's fine. It when you use it all the time or use a ton of it that it's no good. I carry a can with me just in case.
That said, your relay is probably done. Take an ohm reading of all the glowplugs, more than likely they are shot (that contoller for these years like to fail in the on position frying te plugs). Shouldt read more than 1 ohm's
Old 09-23-2010, 07:12 AM
If you ask any IDI purest, they will actually tell you anything below about -15* ether should be used instead of glow plugs as your batteries might not crank fast enough after the glow plugs at those temps.
