6.9L to 7.3L powerstroke swap - Ford Powerstroke Diesel Forum
6.9L IDI Diesels Technical discussion of topics related to vehicles powered by the 6.9 Liter In-Direct Injection Navistar engines.
post #1 of 10 Old 04-14-2010, 11:58 AM Thread Starter
kuti6.0's Avatar
Exclamation 6.9L to 7.3L powerstroke swap
i have a 1985 f250 with a 6.9L I.D.I. diesel that is 2 wheel drive and has a 4 speed manual ranny. i want to put my buddy's 7.3L powerstroke motor into it and do a complete motor swap. i was wondering what it would take to pull off this swap and what i would need to do. i would really like to keep the manual tranny and was also wondering if the old for manuals would fit onto a newer powerstroke motor.
kuti6.0 is offline
post #2 of 10 Old 04-14-2010, 12:06 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
powerstroke? theres gonna be a lot to move over, it was a idi, then it should be minor stuff.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 10 Old 04-14-2010, 12:15 PM Thread Starter
kuti6.0's Avatar
i mean, my 6.9 runs real strong but i just love the sound and the power capabilities of the 7.3 psd
kuti6.0 is offline
post #4 of 10 Old 04-14-2010, 12:17 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
and thats true. idis are stong engines but have limited mod capabilities lol.
im not sure if the cross member fits right off and what has to be moved are the electronics since its not mecanical.
but hopefully someone chimes in. ill post this link in the obs chat thread to get some members in here.
Sold
LSP Group Threads
Jarrod B is offline
post #5 of 10 Old 04-14-2010, 12:18 PM Thread Starter
kuti6.0's Avatar
alright thanks man.
kuti6.0 is offline
post #6 of 10 Old 04-14-2010, 04:02 PM
FordGuy100's Avatar
Motor mounts are the same, tranny bolt patterns are the same (though on automatics the torque converters bolt pattern is different. If you have a powerstroke with all the wiring, have at it. It should slip right in place. Might need a big hammer to push back the firewall a little bit, but it should go right in.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #7 of 10 Old 04-14-2010, 06:46 PM Thread Starter
kuti6.0's Avatar
The only thing I'm missing is all the wiring. Lol I can probably get all that bc my buddy just did a cummins swap in his 95 psd
kuti6.0 is offline
post #8 of 10 Old 04-15-2010, 11:33 AM
lugnut1009's Avatar
Quoted: 8 Post(s)
Could you get it from ''Painless"?
SOLD (AND SORELY MISSED):1996 F250 CC SB ZF5 4WD
9000LB Ramsey winch, 3" dp, straight exhaust, superchips mini max, 6637 filter,
4" Superlift, 315/75 Toyo MT's, custom step bars
2011 F150 CC 2wd with V6 Eco-boost
factory twin turbo and intercooler, 365 hp and 420 ft/lb torque
lugnut1009 is offline
post #9 of 10 Old 04-22-2010, 05:08 PM
ryandamo's Avatar
someone makes a standalone wiring harness i thought? its definitely doable, ive seen a 7.3 powerstoke stuffed in a 79 pickup
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #10 of 10 Old 08-20-2013, 06:52 PM
Is there someone that makes a stand alone harness, because I'm doing the same swap in my 91
91psdf350 is offline
