Anyone have a tcm go bad - Ford Powerstroke Diesel Forum
6.7 Tranny Problems 6.7 Tranny Problems
User Tag List
 1Likes
  • 1 Post By ZMANN
post #1 of 9 Old 07-20-2014, 09:59 AM Thread Starter
I have a tuned and deleted 13 that has been deleted for about 15k miles. Never an issue til last week. I was installing an 8" lift kit. Did the rear, went to start my truck to move and it wouldn't. I jumped it and it started right up so I couldn't figure why the battery would die.
I go on to install front lift and my truck lost communication with the tcm and now won't even turn over. I can hear something bouncing around in the tcm. Dealer says my chip completely erased my tcm but I think a part broke off in it.
Just curious if anyone had one break or go bad.
It's only a 200 dollar part so I'll probably just pay for it per their recommendation so the ford higher ups don't come out to look at it and void my warranty but I don't want it to happen again.
Fwiw, I only used an impact for the rear suspension but needed an air hammer to drive the rivets out on the front for the 4 link. I'm wondering if the banging could have broke the part but then I think how could it, since it's not any worse than driving down a bad road
2013 f350 lariat loaded
8" lift, 38s on 20x12s
Chipped, deleted, and ticking like most 60k dollar vehicles should
superdave99gt is offline
post #2 of 9 Old 07-23-2014, 07:12 PM
Can you post pics? I highly doubt you broke that metal module unless you struck it directly with a hammer.
Did you?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #3 of 9 Old 07-24-2014, 04:46 AM Thread Starter
Well that was the problem. Tcm broke. I did not hit it with anything but there was definitely something broken in it. Dealer said it read completely blank.
post #4 of 9 Old 07-24-2014, 04:49 AM
Sounds to me like the dealer just screwed you. But its not my money so oh well.
These things just dont "break"
wreedPS is offline
post #5 of 9 Old 07-24-2014, 05:39 PM Thread Starter
You must have missed where I said above it did just break. It was in front if my house working then wasn't. I have the old tcm now and there is a small electronic part that is broke off
post #6 of 9 Old 08-18-2014, 07:05 PM
HighHP's Avatar
You must not have much experience in this area. The engines I work on are common to "just break" an ECM. Mostly operator error from turing off a battery disconnect before the ECM can power down from the key shut off. It doesnt happen every time but usually when I get a call to a no start with no ECM communication then thats the problem. Youd be amazed how delicate the internals on all the things are, one little piece of a board screws up and they will wipe the Cal and become completely useles.
OP be happy its only $200, a Cense CM530 can set ya back $10k.
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #7 of 9 Old 08-18-2014, 07:12 PM
ZMANN's Avatar
Quoted: 510 Post(s)
open that puppy up and take a look see
HighHP likes this.
06 KR 4x4 BPD remote OEM Oil cooler /EGR cooler/water pump6 phase FICM , ARP studs,
Rize 4 link Toyo 37" camper modified special
For a truly terrible firearm experience I suggest Taurus
ZMANN is offline
post #8 of 9 Old 08-18-2014, 07:17 PM
HighHP's Avatar
Buddy sunk his dodge halfway up the doors this summer and flooded the interior. The 4x4 modules mounted inside the the cab at the passenger kick panel. Thing looked perfect from the outside when we found it, popped it open and was just a giant green ball of fuzz inside! Id like to see the inside of this one as well!
HighHP is offline
post #9 of 9 Old 08-18-2014, 07:50 PM Thread Starter
It looked good inside except the small electronic piece that had broken off. No water or anything. The unit was still factory sealed
