Possible Transmission Issue? - Ford Powerstroke Diesel Forum
6.7 Tranny Problems 6.7 Tranny Problems
post #1 of 6 Old 03-06-2013, 03:33 PM Thread Starter
79_bronco's Avatar
Hello All,
I recently bought a new 2012 F-250 CC SB Lariat. I am thinking that I possibly have some sort of trans issue. The truck only has 350 miles and when I had originally called the dealer about it, they told me it was a "learning transmission" and to give it time.
The issues:
1. Shifts from first to second gear are fairly hard and almost feel like a lunge, but are much smoother when i do not accelerate fast.
2. Shifting going around corners in 2nd - 3rd or 3rd to 4th are hard and almost feel like it is going in to neutral or missing the shift.
I will say that I noticed these issues at first but they were all magnified after I was with a buddy and gunned it off the line at a stop light (not wide open but still fast).
The truck is at the dealer now to get the spray in bedliner installed and an undercoat, and I asked them to also take a look at this, but want to get all any feedback anyone here may have (I don't have a super high trust level with the dealer honestly).
Another thing that made me think and question a few things, is since the manufacture date was back in June or July, should i be concerned that it hasn't had an oil change or anything yet? Anything else I should do since it has technically been sitting for 8 months?
79_bronco is offline
post #2 of 6 Old 03-16-2013, 07:39 PM Thread Starter
79_bronco's Avatar
They applied TSB 12 - 5 - 12 and it is MUCH better now.
post #3 of 6 Old 04-15-2013, 05:16 PM
mine was doing something similar and now
I will be getting a new transmission pump as soon as it comes in. I believe a service bulletin 13-1-2 was the one that covered it. There is also 13-01-13 and 12-09-04, but don't know what those cover specifically. Mine was having a delay going into reverse and also sporatically shifted very hard in the lower gears.
CamdenDawg is offline
post #4 of 6 Old 04-15-2013, 05:21 PM Thread Starter
79_bronco's Avatar
Mine seems to have good and bad days as far as hard shifts. I have realized when its cold it usually shifts harder but was told that is normal. As far as the jumping around and feeling like it has missed gears. That has only happend once and I just hit 2000 miles this week.
How many miles do you have?
2012 F-250 Lariat Crew Cab Short Bed 4x4 FX4
Ranch Hand Front and Rear
30in Rigid E Series Light
Bilstein 5100 Series Shocks
Truck Cover USA American Work Cover with Toolbox
Kenwood DNX570HD Head Unit
post #5 of 6 Old 04-15-2013, 05:31 PM
kirbybc12's Avatar
Can't speak for the learning part since I got my truck with 12,000 miles, but they do shift hard when cold. Also have hard shifts between third and fifth gear at 12-1400 RPMs going about 30-40 mph
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #6 of 6 Old 04-15-2013, 06:04 PM
Mine has 32k miles on it and
it has good days and bad. 95 percent of the time it shifts as smooth as silk going into reverse as well as going through the forward gears. There have not been any instances where I would suspect that it missed a gear, but rather it hesitates before slamming into the next one. Going from neutral to reverse first thing in the morning can give you quite a jolt. From what the Ford Tech told me, the pump loses its prime and does not retain a full fluid level in it if it sits for very long, therefore it has to re-fill and thereby produces the jolt. I really haven't noticed whether it is temperature sensitive or not. Either way, it gets a new pump.
