Tranny Pan Gasket - Ford Powerstroke Diesel Forum
6.7 Tranny Problems 6.7 Tranny Problems
Old 01-10-2012, 07:29 AM
Feedback Score: 3 reviews
Send a message via Yahoo to fdchief
Tranny Pan Gasket
Took my truck in for service last week and the tech informed me my gasket was showing signs of a leak and they replaced it. said it wasnt a drip yet but was wet from around the middle of the pan all the way to the corners. anyone else had any gasket issues? Truck just hit 20k miles.
Old 09-07-2012, 10:03 AM
Yep 20k on mine too. I just took it in for the second time as their first attempt to fix my leak (via gasket) did not work. They called me today (Helfman Ford) and told me they need to replace a different gasket! It got worse... The gasket won't be here for a month!!! I will keep you posted. Did the gasket fix your leak?
Old 09-07-2012, 08:00 PM
So ford put my truck back together without the new seal (output shaft seal) as it is back ordered for a month. The service adviser said it is not leaking enough to be overly concerned and I should be fine till the seal comes in.. Guess I will watch the tranny fluid like a hawk. I forgot to mention that the first attempt to fix my leaky tranny was to replace the tranny pan gasket.
I love my 2011 F250 and I hope I don't have all the problems I've had in the past.
Old 09-07-2012, 09:16 PM
Huh, even if the gasket is a reusable and lifetime one? It's even stamp on the pan saying that,man when is ford going to get this right?
Old 09-08-2012, 09:19 AM
Got a 2012 with 1800 miles on it. When I was underneath it draining water from my fuel filter I notice transmission fluid around the rear of my pan. Just dropped it off at the dealership. Hope they fix it right.
Old 09-10-2012, 07:29 PM
Louiecvt please let us know how it goes.
Old 09-11-2012, 06:18 PM
Just got it back today. They said they had to replace the gasket. Of course they had to order the part so it took two days. Went under the truck when I got home and everything's seems fine. I'll be keeping a close eye on it though.
Old 10-27-2012, 01:12 PM
Mine is at the dealer (for the third time) now with the same issue, leaking around the rear of the transmission. They have now had the truck for 10days, and the service rep says the tranny tech will be replacing the pan gasket monday. I informed him that they replaced the gasket once already and it did not fix the problem. From the little bit I looked at it, I think the fluid is coming out of the parting line where the transfer case is mounted to the back of the transmission.
