2-3 shift issue - Ford Powerstroke Diesel Forum
6.7 Tranny Problems (2011-2016) 6.7 Tranny Problems
post #1 of 9 Old 03-20-2014, 05:57 AM Thread Starter
2-3 shift issue
My truck doesn't seem to like the 2-3 shift. More often than not, it seems to want to hold 2nd gear until it finally shifts 3rd. No tuning or anything on my truck and it only has 6000 miles. Any thoughts? Should I take it to the dealer? I'm worried they'll try to screw me over because of the lift even though it did it beforehand.
2012 CCLB F250 Lariat 4x4 6.7L
Rigid Industries 20" E-Series-Husky Liners-S&B Intake
Pure Performance 4" Triple Threat-PMF Dual Steering Stabilizer-Method NV-315 70R18 Toyo M/Ts
5-0stank is offline
post #2 of 9 Old 03-20-2014, 06:00 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Don't worry about your lift. There is a Flash that takes care of your shifting issue, I had the same issue as what your describing and the update took care of it, smooth as butter now.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 9 Old 03-24-2014, 07:37 PM
Quoted: 2 Post(s)
Yes x2 take it and get it flashed at the dealer or by a tech with the Ford computer.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #4 of 9 Old 03-28-2014, 04:34 PM
Unclesams_PSD's Avatar
Quoted: 2 Post(s)
I had the same problem and the flash did not fix my issue. After bringing it in time and time again they finally changed a solenoid in the transmission. I just got the truck back a few days ago, but so far so good. I hope that was the problem because it was getting old and it was doing it since 4-5k miles on the truck, I now have 33k on it.
2011 F250 Lariat CC/4x4 Mods: Stock height with 35's
-Toy Hauler
1986 Ford Mustang SVO / Mods: Just a bigger turbo
-Fun car
2009 Pontiac G8 GT Mods: just some apperance stuff and 20's
- Family car
2014 Ford Focus ST: Stock
- Daily Beater
Unclesams_PSD is offline
post #5 of 9 Old 11-07-2014, 10:19 PM
Drivin the 6.mOney pit
armyguy209's Avatar
Feedback Score: 6 reviews
Mine is bone stock as well and doing this between 3-4. It is also sometimes pausing a few seconds going into reverse. Mine is a 2015 with 6k miles on it. it didn't start doing it until I got back from hauling an 11k lb load to and from Montana. I'm dropping it off Tuesday but I have a big feeling they are going to tell me it's normal and they can't feel anything wrong. if that's the case, I'll drive the crap out of it till it breaks. also have a very annoying rattle in the rear driver side door, A/C recirculation door isn't working, and have some kind of popping noise in the suspension/frame area when the chassis flexes a little going from a flat road to an incline. All not a good start for my brand new $65k truck.
Dan's baby
2006 F250 CCSB Lariat 4x4 with 2007 CR 5.9 Cummins/built Allison swap and other goodies-sold
2015 F350 CCSB 4x4 Lariat Ultimate in Black tuxedo metallic
US ARMY VET
Operation Iraqi Freedom III (1 YR served in the good ol' sandbox)
armyguy209 is offline
post #6 of 9 Old 11-09-2014, 07:11 PM
DIGMAR's Avatar
Quoted: 25 Post(s)
I had it in mine as well. did the reflash, fixed it for a while then came back. finally replaced a few of the solenoids and fixed it. I will say that I still have the delay coming out of 2 into 3 when the tranny is cold. after it heats up it's smooth.
2012 F250 Lariat CCSB SRW:
H&S XRT w/ Gearheads tunes, Edge CTS, 5" FLO PRO DP Back w/ Muffler
S&B CAI, EGR Block Off Plates, No Limit CCV
Retro HIDs, ProComp 2.5" Stage3 level/lift, Fox 2.0 IFPs, 295/75/20 Toyo AT IIs
DIGMAR is offline
post #7 of 9 Old 11-20-2014, 10:06 AM
GLIofMI's Avatar
Mine is 2-3 and 4-5 and a reverse hesitation. It was fixed at the dealer, 3 new solenoids, parts & labor=$428.04.
Plus they did a passenger wheel hub.
Unfortunately 221,000 miles is too much for anyone but me to pay for it.
So for those of you with low miles, get them in and fixed with their money not yours.
283K, Still Runnin
GLIofMI is offline
post #8 of 9 Old 12-03-2014, 03:54 PM
There's a tsb out for certain months n years for the solenoids. I changed mine myself, cost like $100 plus fluid. Runs better. Tho every now n then same 2-3 hesitation if I'm easy on the pedal. Think u just have to drive these trucks hard like they're meant to be
Frederick67psd is offline
post #9 of 9 Old 12-05-2014, 09:45 AM
DIGMAR's Avatar
Quoted: 25 Post(s)
once in a blue moon I still get the reverse hesitation. usually right at start up if the trucks been sitting a long time, overnight or all day at work, has only happend about 3 times. once since the new solenoids, put it in R, nothing happens for a while, shift back to P, and then to R again and works. not even worth taking in since I know it will never happen while at the dealer. had them add the notes two different times i had it before they replced the solenoids so hopefully if something goes out in the future it will be somewhat coverable... doubt it though.
DIGMAR is offline
