Tranny Delay - Ford Powerstroke Diesel Forum
6.7 Tranny Problems (2011-2016) 6.7 Tranny Problems
post #1 of 10 Old 11-13-2013, 07:16 AM Thread Starter
Blackie13's Avatar
Tranny Delay
When I stop on a hill, it can be a very slight hill, the tranny seems to stick. When I release the brake the truck does not start moving. What ever is going on does cause some resistance because you have to give a lot of diesel to break it free. truck revs like you are power braking. At first I thought it only did this when cold, but have come to realize it does it all the time. I thought it could be the option that you can get that prevents the truck from drifting backwards on a steep grade but I don't have it listed on my invoice and if it worked the way my truck is driving I would not want it anyway. Any Thoughts
Blackie13 is offline
post #2 of 10 Old 02-05-2015, 01:20 AM
Kustom4x4's Avatar
My truck does same thing, is this normal? Anyone have any ideas? Also I took off from a dead start and after I took off it did it say from 2nd to 3rd or 3rd to 4th kinda bothers me being a brand new truck.....
01 Platinum
8inch lift
22x11 KMC Diesels/37x13.50 Kumho MT's
2015 Platinum Bronze fire
Soon to come
4" BDS lift
22x12 American force wheels and 35's
Kustom4x4 is offline
post #3 of 10 Old 02-05-2015, 04:06 AM
DIGMAR's Avatar
Quoted: 26 Post(s)
I know when your parked on a hill it will do this and is normal. Its a break to prevent you from rolling back. If its staying on once you start forward movement, thats a problem you may want the dealership to look at. I noticed it when I first got my truck and was pulling up out of a boat ramp, scared me at first but once I figured out what it was it was kinda nice to have... but again, it should disengage once you start moving forwards.
2012 F250 Lariat CCSB SRW:
H&S XRT w/ Gearheads tunes, Edge CTS, 5" FLO PRO DP Back w/ Muffler
S&B CAI, EGR Block Off Plates, No Limit CCV
Retro HIDs, ProComp 2.5" Stage3 level/lift, Fox 2.0 IFPs, 295/75/20 Toyo AT IIs
DIGMAR is offline
post #4 of 10 Old 02-05-2015, 05:32 AM
Kustom4x4's Avatar
Guess I'll have it checked out but it's not everytime, and it's not on a hill, flat pavement, the one that really bothered me was the one where I was already rolling then it's like it had a hesitation enough to throw me foward a tad....truck only has 3400 miles on it.....
01 Platinum
8inch lift
Soon to come
4" BDS lift
post #5 of 10 Old 02-05-2015, 05:39 AM
Rattler1's Avatar
Quoted: 22 Post(s)
Mine does the same thing. It is the hill start assist feature. It does seems kind of weird at times.
Between that and the weird times the traction control engages the front brakes, I think there may be some parameters in the ecm that are off.
2015 F250 XLT crew cab long bed 4x4.
Rattler1 is offline
post #6 of 10 Old 02-09-2015, 11:19 AM
DIGMAR's Avatar
Quoted: 26 Post(s)
well... other than the OP, this seems to be somewhat of a trend on the '15.
DIGMAR is offline
post #7 of 10 Old 05-26-2015, 03:52 PM
Quoted: 10 Post(s)
It's supposed to do that.
The option you are talking about is hill-descent mode which is something different.
Read your book.
a.hoglen is offline
post #8 of 10 Old 05-26-2015, 06:17 PM
DIGMAR's Avatar
Quoted: 26 Post(s)
Not talking about hill descent... Yes the truck is supposed assist when taking off from a decent slope, but should not be holding on that long... If it's holding on till 3rd, something's off.
DIGMAR is offline
post #9 of 10 Old 06-01-2015, 02:03 PM
HSA....Hill Start Assist...
2014 F250 Platinum 4x4
4"-4Link BDS Lift, BDS Dual steering stabilizer, Fox 2.0 Shocks.
20" x 10" Fuel Rampage wrapped w / 35x12.50x20 Toyo's
AMP Power Steps
H&S MM w/ Gearhead Tunes / No Limits EGR Delete . Flo-Pro 4" downpipe back w / muffler S&B CAI.
[SIGPIC][/SIGPIC]
RigTrash601 is offline
post #10 of 10 Old 06-05-2015, 10:18 AM
twood71's Avatar
Quoted: 4 Post(s)
Yes ^^^^^ Yes
This sensor sense the elevation and applies the breaks as suppose to so you don't roll back once you take off. If you baby take off it will keep sensing the elevation and keep the breaks applied.
Dear God, I've been very good today. No grumpy thoughts, no swearing, no smacking people in the head and no whining at all!
BUT, I'm about to get out of bed now, so I need your help with the rest of the day!
TONY.
2015 FORD F350 6.7 POWER STROKE TURBO DIESEL XL 26 gallon TANK on 156" wheelbase
6.7L Power StrokeŽ with best-in-class power, standard torque and fuel economy
twood71 is offline
