Normal Trans temp - Page 3 - Ford Powerstroke Diesel Forum
6.7 Tranny Problems (2011-2016) 6.7 Tranny Problems
post #21 of 29 Old 07-16-2013, 04:41 PM
johnh7's Avatar
3:55 rears f-250 towing a 40ft gooseneck (9900lbs trailer weight) and 13000lbs cargo weight truck did great and tranny temp ranged from 197-215 and engine oil temp 200-220.
truck did great! again im very impressed on how this truck can handle itself with a decent load.
-- John Huber -- SGT RET --
l'12 F-250 King Ranch l Black Tuxedo l
johnh7 is offline
post #22 of 29 Old 08-22-2013, 07:20 PM
I took that big wind deflector off from under the front bumper and run 10-15 degree cooler on the trans and 20 on the engine oil
TOY1TON is offline
post #23 of 29 Old 08-25-2013, 05:41 PM
I'm towing a 9000 lbs camper into a headwind and going up hill, all at 62mph. The trans temp is staying under 210. Engine oil up to 240 degree F. I'm glad I put the synthetic 5w-40 in her belly before we took off. I run 200 trans and 200 engine oil running unloaded.
2013 F350 CC 6.7 4x4 Lariat 3.31
Black, Leer Cap, 18" Wheels
Grandpa's Camper Puller
dbj216 is offline
post #24 of 29 Old 09-05-2013, 06:36 PM
Quoted: 2 Post(s)
Originally Posted by Bonesman View Post
I see 196* all of the time on my 6.7 while on the highway. No worries.
This is what I see too all the time. Trans loves that temp.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #25 of 29 Old 12-27-2013, 10:15 AM
Check coolant my truck had trans completely rebuilt and ford didn't check levels I drove temps climbed to 240's I stopped checked and was down a gallon and a half of coolAnt filled and temp hasn't moved above 197..
Stiles825 is offline
post #26 of 29 Old 04-22-2016, 10:05 AM
my truck is doing the same... slowly creeping up to 235 degrees driving on the highway.... my oil and coolant stay between 192-200 though. trans always used to be around 196 until a few weeks ago. you just added coolant and it fixed the issue?
dbny111 is offline
post #27 of 29 Old 02-04-2017, 05:43 PM
2011 f350 i run 194 at hottest no towing though
sick350 is offline
post #28 of 29 Old 02-09-2017, 02:02 AM
cprdiesel's Avatar
Garage
Right on good to know
Asphalt Eater,
cprdiesel is offline
post #29 of 29 Old 02-11-2017, 08:35 AM
Quoted: 161 Post(s)
Garage
never seen more than 210 ( Trans ) pulling 16000lbs of round bails in Arkansas's Ozark mountains. Once back to flat land abut 205.
Oil temps ran 230ish at hottest.
212 on flats.
odd to notice on mine. no load running 65 - 75 i get 201 Oil temp.
Running 85-95 while i was in Montana i ran in the 216 range for hours, again oil temp.
Glad i had 5w40 synthetic oil. put 10500 miles on the oil. the report looked great to. You can see it under my Blackstone reports tab.
2011 Ford F-250 Super Duty Lariat
3.31 ELOD 4X4 6.7 Power stroke
01/24/2017 110,000 MI
S&B CAI
SCT X4 Tuner
Running a tow tune by AMDP
( on-demand exhaust brake from the AMDP tune).LED interior,LED AUX back-up,Westin HDX grill guard,High-idle,Aux 55 Gal Transfer tank,Draw-Tite Hide-A-Hitch gooseneck,LED puddle lights.4000x2 LED lights up front for dark country roads. Access Low profile bed cover.
Roof clearance lights.
mwe_060 is offline
