won't start with key - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
User Tag List
post #1 of 9 Old 04-26-2014, 02:18 PM Thread Starter
Sometimes it starts and sometimes it don't with the key.
But it always starts with the remote start
2011 f-350 4x4 crew cab dually
2.5 inch lift on the front
Air bags on the back
200 hp
War hammer spartan and the dpf/cat delete
150 db - 150 psi train horn
Weather tech floor liners
Brand new flat bed
Mattress Guy is offline
post #2 of 9 Old 04-27-2014, 08:23 AM Thread Starter
Any ideas?
200 hp
Brand new flat bed
post #3 of 9 Old 05-01-2014, 11:29 PM
jctgumby's Avatar
Out of curiosity, when it won't start with the key does it almost seem like dead battery? Like a few few hard clicks, but if you try the remote start it fires right up. The reason I ask is my '11 started doing this day before yesterday with 61k on it. I do have some corrosion on the posts of both my batteries. I am going to try cleaning them in hopes that the starting issues go away.
2011 F-250 Lariat FX4
6.7L PowerStroke
All stock supsension
All stock exhaust
35x12.5 Nitto Trailgrappler M/T
Stock 18" wheels
jctgumby is offline
post #4 of 9 Old 05-02-2014, 04:28 PM
jctgumby's Avatar
Well I figured out my problem today. This afternoon it decided it didn't want to start by key or remote. Turns out it was the batteries. If yours is doing the same thing you had better get your batteries checked before you end up stranded somewhere. I was told by a 6.7 technician that these motors need an almost perfect charge to even fire up. Once the batteries begin losing their life they need to get changed out pronto. Good luck
6.7L PowerStroke
All stock exhaust
Stock 18" wheels
jctgumby is offline
post #5 of 9 Old 05-02-2014, 06:21 PM
lug
lug's Avatar
Is it both keys or just one of them? If it's just the one key then have it checked, but if it's both keys it may be the ignition cylinder. The trucks built in security feature may not recognize the keys security code.
2014 F-350 6.7L CCLB DRW Lariat - On duty
2013 F-250 6.7L CCLB Lariat - Sold
2000 F-350 7.3L CCLB Lariat - Sold
1998 K3500 6.5L CCLB Silverado- Sold
lug is offline
post #6 of 9 Old 05-03-2014, 04:21 AM Thread Starter
I don't have 2 keys.
But I have figured out that if I get in the truck
Put foot on brake and turn the key over exactly when the door shuts. It starts ever time.
I don't kno what the door has to do with it.
200 hp
Brand new flat bed
post #7 of 9 Old 05-03-2014, 09:07 AM
lug
lug's Avatar
It's possible slamming the door is jarring a loose connection enough to complete the circuit. Take a look under the steering column and follow the wire bundle to their connectors. You may find one that isn't snapped in all the way causing your problem.
lug is offline
post #8 of 9 Old 05-07-2014, 09:33 AM
Hooked on the POWER...
allenhood71's Avatar
Feedback Score: 6 reviews
Mine started doing the doing the dead battery act this morning with just under 60,000 on it. If I just hold the in the start position, it will eventually start. Gonna get them checked today. Will let y'all know what the status is.
allenhood71 is offline
post #9 of 9 Old 05-10-2014, 07:09 PM
Bad batteries, got them replaced. Have not had anymore issues.
Sent from AutoGuide.com App
