ABS Issue - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
post #1 of 2 Old 04-25-2014, 06:02 PM Thread Starter
<b>Premium Member</b>
BigGreen06's Avatar
Quoted: 63 Post(s)
ABS Issue
I was wondering if anyone else with a 13/14 has an issue with their ABS system, especially when going over bumps. At first I thought it was normal, cause I bought my truck in Nov, and it started snowing shortly after. However I noticed it happening more on dry roads (some dirt, some paved). Let me try to clarify what I'm talking about, the sound you get when you run over the rumble strip on the highway, sounds like that for a split second to a couple seconds, or better example is when you step on the brakes when you're on ice, you get that rumble noise. I get that almost daily, almost every time I drive, sometimes even going over small bumps. Service Manager said that the systems in the 13/14s are just a lot more sensitive than in my 10. I can agree with that somewhat, but not for how often it is happening.
Also starting to think my brakes squealing may be caused by this other issue or could be contributing to the problem.
Any thoughts appreciated.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen; www.oslights.com
BigGreen06 is offline
post #2 of 2 Old 04-30-2014, 11:26 PM
Mines goes off a lot too, seems like if I change angles on both the front to rear and the side to side axis of the truck its pretty touchy. I figure it was the roll/stability controlled doing its normal deal.
11eco is offline
