Another Turbo - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
User Tag List
 3Likes
post #1 of 33 Old 03-20-2014, 04:07 PM Thread Starter
Another Turbo
I have been experiencing the "shudder", the "lugging" ect. I have had it in and out of my local FORD dealer many times on the 2013 F350. At 2k miles put on a new turbo, issue still persists. Just took it in for the same problem. Told me the MAP sensor is bad and caused another turbo failure.
Question, can a MAP sensor sending bad information, cause mechanical damage to the turbo?
This is the third turbo on the truck, 4 "updates" or "flashes", three different flight recorders and this is the answer I have, "new turbo and MAP sensor you should be fine". Seems fishy! Needless to say I am frustrated with a $60k+ truck.
2013 F350 CCSB Lariat Ultimate
4" Fabtec Lift
35" Toyo's
20" Fuel's
Kyle T is offline
post #2 of 33 Old 03-20-2014, 07:36 PM
Read this TSB and see if it fits your symptoms...
Do you get a Cleaning Exhaust System Message just before the issue happens?
There is a TSB labeled 13-05-17
For some reason, I cannot paste the link anymore but it does exist and includes 2013 model engines.
2012 F250SDw/6.7L Turbo Diesel Engine Issue - Need Help !!!
poormanscat is offline
The Following User Says Thank You to poormanscat For This Useful Post:
Kyle T (03-21-2014)
post #3 of 33 Old 03-21-2014, 07:46 AM Thread Starter
I cant seem to find a copy of that TSB online, Seems like its is directed to a Ford Service website that is restricted access.
What I found is people discussing exhaust valve replacement, is that correct?
4" Fabtec Lift
35" Toyo's
20" Fuel's
Kyle T is offline
post #4 of 33 Old 03-21-2014, 01:14 PM
yes, they have to replace the exhaust valves in the l/s cylinder head.u will get the cleaning exhaust system message shortly before this problem occurs
Kyle T (03-21-2014)
post #5 of 33 Old 03-21-2014, 01:21 PM Thread Starter
Does anyone know if the 2014 shares the same turbo as the 2013 model? Im thinking about canning this one and going to something else, just flat tired of dealing with it! Hate to go Cummings or Duramax, but geeeezzzz.....
4" Fabtec Lift
35" Toyo's
20" Fuel's
Kyle T is offline
post #6 of 33 Old 03-21-2014, 07:56 PM
2013-2014 turbos are the same.
post #7 of 33 Old 03-22-2014, 06:57 AM
map signal wouldnt hurt the turbo, that's them just guestimating maybe cutting oil or coolant supply would, but i doubt a damn map signal would.. Hopefully they're smart enough to do a wiggle test on the EBP pigtail and MAP pigtail.... Ive seen the pigtails have bad connections ALOT, and you get a shudder from turbo open/closing real fast, with driving on the highway being the worst. it Dooesnt always throw a dtc either, you have to watch the signal with an o-scope/IDS and wiggle it to tell.
Scumbag is offline
The Following User Says Thank You to Scumbag For This Useful Post:
Kyle T (03-22-2014)
post #8 of 33 Old 03-22-2014, 07:07 AM
Ontario Trucker's Avatar
Sorry to hear all that Kyle, good luck
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
The Following User Says Thank You to Ontario Trucker For This Useful Post:
Kyle T (03-22-2014)
post #9 of 33 Old 03-22-2014, 07:29 AM
fordtrix's Avatar
How many miles are on your truck? I was under the impression that most all the turbo issues were in the 2011's. I have seen VERY few around the forum's on any 13's, unless they were turned and deleted and messed something up from running the psi's too high.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #10 of 33 Old 03-22-2014, 11:39 PM Thread Starter
I have just under 6400 miles on the truck. I had a aftermarket air intake on it when the first turbo went at 2k. It has been totally stock ( except lift and tires ) since.
I too thought most of the problems were with the 2011 and even early 2012. My dealer is telling me they never see these problems. The shop Forman is just doing what he is told from the Ford engineers, but isn't too confident in the fix.
4" Fabtec Lift
35" Toyo's
20" Fuel's
Kyle T is offline
