Yet another victim of a bad EGT sensor - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
post #1 of 15 Old 03-20-2014, 06:13 AM Thread Starter
Quoted: 11 Post(s)
Just after going over 10K miles, the check engine light came on in my 2013 F250 6.7L last week. I pulled the code with my reader and it came up as P208C, which a google search describes as "Reductant Pump Control Circuit Low." Reductant is what Ford calls the DEF.
Dropped it off at the dealer and they're telling me it's a bad EGT sensor, which doesn't seem to fit the code description I pulled, but I guess I have to defer to them. I'm getting it back this morning but now I'm paranoid about the EGT sensor failing on me. I plan on taking several road trips soon, including a 3K mile trip out west.
I just ordered an extra EGT sensor in case I have to change it on the fly. Does anyone have instructions on where the sensor is located? It seems like a pretty easy install if you know where it is. Unscrew and unplug, then screw in new probe and plug in the other end.
Drewtk is offline
post #2 of 15 Old 03-20-2014, 07:29 AM
fordtrix's Avatar
Did it put your truck in limp mode and leave you stranded? I had a sensor around 10k miles. Brought it in at next oil change and they fixed it. Was no issue at all. Now I have around 33k miles on my 2013 and no other issues other than that.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #3 of 15 Old 03-20-2014, 02:51 PM
there's 4 egt sensors, any one of them can leave ya stranded, but egt 12 and 13 are the most common, the middle 2 of the 4. The pull over safely shutdown usually results in a 1 hour lockout timer, that prevents you from starting the truck. You can get around the timer by running a koeo self-test with an IDS. if it does go out, you can literally just wait there and it will eventually start and run. Everytime they get towed in, in reach in, start it right up drive it in the shop
Scumbag is offline
post #4 of 15 Old 03-23-2014, 07:29 PM Thread Starter
Quoted: 11 Post(s)
UPDATE: The dealer initially said an EGT sensor was bad and replaced it, but turns out the DEF pump was going bad, so they replaced the pump and said the problem was fixed. I just got back from a track weekend towing my race car trailer 400 miles and everything seems fine.
What's strange to me is the engine code description was "Reductant Pump Control Circuit Low" (Reductant is DEF) so I'm not sure why the DEF pump wasn't the first thing the dealer checked. I mean it's right in the description.
I went ahead and ordered an extra EGT sensor just in case. I don't want to get stranded by a $40 part.
Drewtk is offline
post #5 of 15 Old 04-06-2014, 02:39 PM
skyfuzz's Avatar
Same thing happened to me today. I have a 2011 F250 with 50,400 miles. Pulling into the neighborhood got the ole "pull over safely" notification and BAM! Everything was gone. I has it towed to the nearest dealership and the first they told me is $150 to diagnose and sensors are not part of the "drivetrain". I. told the writer if the truck will not run because of the sensor then obviously it was part of the drivetrain, he gave me nothing but a blank stare back. I'm seriously considering the First Coast Diesel Performance option of the tuner and exhaust. Apparently you can get ride of these sensors and DEF all together. Thoughts on he tuner and exhaust upgrades? Has anyone had any problems?
skyfuzz is offline
post #6 of 15 Old 04-06-2014, 03:26 PM
Just had it happen to me on my 11 model C&C. I was running about 55-60mph on a 2 lane highway with no shoulders and it suddenly chimes pull over safely. At the same time it completely shut the truck down! I ended up running off the road due to not being able to steer or stop. The shutdown command needs to give some defuel time to safely get off the highway before shutting the engine down. Maybe de-fuel and force back to 1st gear 1500rpm max?
With all the crap the gubbament is giving GM over the ignition swtich fault, I cannot see how Ford is any less to blame.
poormanscat is offline
post #7 of 15 Old 04-06-2014, 09:54 PM
Quoted: 2 Post(s)
^wow, that's horseshi+. Can't believe that a damn work truck would just shut off like that- thank goodness you weren't pulling a fifth wheel.
swiseuf is offline
post #8 of 15 Old 04-06-2014, 11:33 PM
strokersixo's Avatar
Quoted: 31 Post(s)
I'm SO glad I own a 06 6.0l, after reading this thread none "pull over safely" and shutdown stuff, truck just runs. YES there are weak links, but fix them, and you've got a nice solid reliable truck. I have 127k and truck runs like a champ.
--MAX--
strokersixo is offline
post #9 of 15 Old 04-07-2014, 04:21 PM
yeah, it could have been worse. with the truck weighing about 18.5K theres not a lot of turning when you lose the power steering. For something as insignificant as an EGT sensor failure seems like they would simply derate it to the point the truck would slow down to 1st gear and give you 5-10 minutes to get it to a safe place to pull off.
Not every sensor failure is going to happen in front of a parking lot!
post #10 of 15 Old 04-08-2014, 09:47 AM
Cratos's Avatar
deleting fixes it forever
2012 F-250 4X4 FX4, SCLB, 3:55's , Camper & Tow package, air lift bags and pump, Edge insight. Dark Pearl Blue.
Cratos is offline
