Water in fuel light on but no water. - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
post #1 of 8 Old 02-22-2014, 10:15 AM Thread Starter
I have the light light on but have drained bowl 3 times without getting water. Says reduced power as well. Cleaned connections without any success. Any thoughts? Does anyone have resistance specs on sensor so I can check that to see what it is reading. This is driving me crazy!
skinny1030 is offline
post #2 of 8 Old 03-07-2014, 04:53 PM
Pull the drain plug and spray the hell out of it with carb cleaner. Use a lighter to bend the straw 90* so you can spray up towards the sensor. Wax and junk accumulates in there and shorts out the sensor. You'll be amazed what you clean out. Count on using the whole can.
2005 Excursion Limited 6.0L 2wd
Atlas 40, Bulletproof EGR cooler, coolant filter, 6.4L banjos, Cat coolant, Gogo direct solenoid, 7.3 fan clutch. Otherwise, all stock.
bigric is offline
post #3 of 8 Old 03-07-2014, 04:54 PM
Just realized I'm in the 6.7 forum. This works on the older trucks...
bigric is offline
post #4 of 8 Old 03-11-2014, 11:21 AM
brendan.9's Avatar
I've been having the same problem, put a titan tank in and had a mishap and was sucking in snow so it froze up and didn't tell me there was water in there but when i tells me there is water there isn't. I try and delete it with my mini maxx and it usally takes multiple times turning key on and off and clicking the delete dtc and discontenting the battery also its getting a pain in the a**
2013 F350 5" straight exhaust, Mini Maxx, CAI, H&S egr delete
03 SVT Cobra Whippled 632 rwhp 572rwtq Torch red 10th Anniversary coupe.
brendan.9 is offline
post #5 of 8 Old 03-15-2014, 09:04 PM
The WIF counter in the pcm needs to be reset, make sure harness side connector doesnt have water in it.
Scumbag is offline
post #6 of 8 Old 03-30-2014, 04:03 PM
Is that something that only the dealer can do?
2013 Lariat FX4 CCSB Blue Jean Metallic
NAVY CHIEF, NAVY PRIDE!!
2013BigBlue is offline
post #7 of 8 Old 03-30-2014, 04:50 PM
Yes, or somebody that has an IDS ford scantool. It literally takes less than 5 minutes. I see it alot when people leave them unplugged for a while. Something happens with the the pcm to where that counter has to be reset or the light/derate never goes away. Its in toolbox> powertrain> service functions
The 6.4's would occaisionally do the same thing but the 6.7s are way more sensitive to it.
Scumbag is offline
post #8 of 8 Old 03-30-2014, 05:18 PM
Thanks, and I'm sure the dealer will charge a fee for doing such pain staking task...
