truck not going over 75 - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
User Tag List
post #1 of 8 Old 01-24-2014, 07:05 AM Thread Starter
Friend of mine has a 6.7 i talked him into buying. he called last night a couple of states away and has been having issues. It is out of warranty and he hasn't deleted yet but they replaced a fuel pressure regulator on one side and now tell him it is the hpfp. It will drive okay up to 75 mph last night while pulling a 4000 lb enclosed trailer. I am not a diesel mechanic but the longer I talked to him the more it seemed like a fuel supply problem not a hpfp problem. I would think if you could get to 75 and it won't go any higher it is running out of fuel but more likely it is a volume problem of it getting to the hp pump rather than the hpfp not working properly.
Any advice would be great. He doesn't have a scanner but is supposed to go by autozone tonight and get the code for the check engine light so i can research it for him
2011 f250 Ccsb 4 x 4 brown lariat black leather
Spartan war hammer afe intake bestop power steps toyo mt 35 x 12.5 x 20
08 F250 cc sb 4x4 Spartan 300 kem 345 dd 4" power stroker 67 4" afe down pipe back exhaust with muffler 37" toyos afe stage 2 si 3" cac pipe
Elite Egr Cooler delete with Wastegate.
Viair on board air system
New custom painted winch bumper with mile marker winch
Hidden hitch
Soon to be n fab steps
Sony nav
Custom steering wheel
Homemade traction bars
spderjhn is offline
post #2 of 8 Old 01-27-2014, 05:25 PM
lug
lug's Avatar
MyKey Does he have this? Previous owner could have set a reduced speed assigned to that key.
lug is offline
post #3 of 8 Old 01-28-2014, 06:44 AM
Agree with lug. He needs to check the MyKey. If a top speed was set, he should be able to clear it using the dash menu.
2012 F-350 Crew Cab Lariat 4X4
H&S XRT Pro; DPF deleted; S&B Air Intake
2006 F-350 Crew Cab XLT 4X4 *SOLD*
hmdavid is offline
post #4 of 8 Old 01-28-2014, 06:49 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
It def. sounds like previous owner has setup Mykey with a speed limiter. Hopefully this is the culprit.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 8 Old 01-28-2014, 07:08 AM Thread Starter
It's throwing codes dealer has been throwing parts at it and says is hpfp that just doest sound right based on his explanation.
Sent from AutoGuide.com App
Hidden hitch
Sony nav
spderjhn is offline
post #6 of 8 Old 01-28-2014, 09:24 AM
greygearhead's Avatar
The shop he went to is looking to make big $$$$ from an out-of-towner! Start with the cheap stuff; fuel filters if the mykey isn't the fix. Make sure he's at the shop to see what's in the filters when they pull them, too. DON'T trust them.
2012 F350 2wd srw 8' Lariat 6.7
2004 Ranger FX4 Level II
2008 Mustang Bullitt dhg
greygearhead is offline
post #7 of 8 Old 01-28-2014, 11:09 AM Thread Starter
He said he had just had filters changed and watched them do it but I recommended him try replacing again just in case had a bad filter
Hidden hitch
Sony nav
spderjhn is offline
post #8 of 8 Old 02-08-2014, 07:08 PM Thread Starter
P228f is his error code
Hidden hitch
Sony nav
spderjhn is offline
