Truck pulls to left when braking - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
User Tag List
 3Likes
post #1 of 21 Old 01-01-2014, 02:14 PM Thread Starter
Hey guys my 2012 pulls to the left when applying the brakes. The steering wheel will want to go in the opposite direction if I am not holding it.
Any ideas on what I need to go? I have about 40k miles.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #2 of 21 Old 01-05-2014, 09:39 AM Thread Starter
Bump any ideas?
wreedPS is offline
post #3 of 21 Old 01-06-2014, 05:56 PM
rvdb's Avatar
first off I have no answer unfortunately, my 13 does the same thing, I was thinking it was the stock already cracking tires I guess it may be more than that, good luck. I will keep an ear out..
rvdb is offline
post #4 of 21 Old 01-06-2014, 06:37 PM
Heavy_GD's Avatar
Quoted: 478 Post(s)
Feedback Score: 3 reviews
Stuck caliper.
Colin7.3 likes this.
GD - 06 CCSB FX4 Lariat
Originally Posted by G8orFord View Post
My magic wand broke a few years back when my crystal ball fell on it. Ruined the ball too. So we're going to have to figure this one out another way. YOU NEED A MONITOR or at least a good scanner.
Heavy_GD is online now
post #5 of 21 Old 01-06-2014, 06:47 PM
Colin7.3's Avatar
Check your slider pins to make sure they are not frozen.
Heavy_GD likes this.
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #6 of 21 Old 01-07-2014, 08:50 AM
greygearhead's Avatar
I'd say right front disk brake failure, and the other guys above are correct as to possible issues. Tire problem is possible but very unlikely.
2012 F350 2wd srw 8' Lariat 6.7
2004 Ranger FX4 Level II
2008 Mustang Bullitt dhg
greygearhead is offline
post #7 of 21 Old 01-07-2014, 09:47 AM
Sounds like a stuck caliper or slider pin.
2012 F-350 Crew Cab Lariat 4X4
H&S XRT Pro; DPF deleted; S&B Air Intake
2006 F-350 Crew Cab XLT 4X4 *SOLD*
hmdavid is offline
post #8 of 21 Old 01-12-2014, 05:44 PM Thread Starter
Yes I think so to. I need to do the brakes so I ordered everything. Hope to get to it in the next week or so.
wreedPS is offline
post #9 of 21 Old 01-12-2014, 09:12 PM Thread Starter
I had the tires recently rotated and balanced and it made no effect on braking.
What makes you think it is the right caliper?
When I brake the truck wants to go to the left and the steering wheel will pull to the right.
wreedPS is offline
post #10 of 21 Old 01-12-2014, 09:39 PM
Corey@CNCFAB's Avatar
Quoted: 156 Post(s)
Right caliper is sticking and won't grab. Steering pulling to the right I'd say is bad alignment.
E99CCLB 250/200s,STG1cam, KC38R, 4" exh,CNC FAB fuel&oil lines,140vIDM,BTS,S&B
97 ECLB F250 4x4 all stock
96 CCLB F350 4x4 D60 swap stock
EDGE,S&B,SCT,PHP Hydra,TS-Perf,OEM parts,Sam Wyse trans,VB's,LED's,MBRP,ISSPRO,ICON,FOX,KC TURBOs,SD 7.3 fuel kits, HPOP lines
www.cncfabricationllc.com or email sales@cncfabricationllc.com
Corey@CNCFAB is offline
The Following User Says Thank You to Corey@CNCFAB For This Useful Post:
TCMSuperDuty (05-02-2014)
