Noisy oil cooler? - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
User Tag List
post #1 of 16 Old 01-01-2014, 01:54 PM Thread Starter
Noisy oil cooler?
Hello,
Is the oil cooler the radiator looking thing mounted on the front of the passenger frame rail?
If so one of my connections makes noise when idling. It is very annoying, if I move it ever so slightly it stops. Any ideas on how to fix this?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #2 of 16 Old 01-01-2014, 01:58 PM Thread Starter
I am thinking this might be the trans cooler guys.
wreedPS is offline
post #3 of 16 Old 01-01-2014, 02:20 PM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
You are correct sir! The oil cooler would be on the driver side mated to the engine. About the size of an elementary school Lunch box. On the inside of the driver side frame rail is a Mini cooler, that's the fuel cooler. What you are looking at is the trans cooler.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 16 Old 01-01-2014, 02:35 PM Thread Starter
Ya man soo the bottom line is very noisy at idle. If i touch it with my hand it is silent.
Could i be low on fluid? I am going to check that in a lil bit.
wreedPS is offline
post #5 of 16 Old 01-01-2014, 02:56 PM
Quoted: 3 Post(s)
Also check the mounting bolts. If it stops when you touch it, it might just be loose?
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #6 of 16 Old 01-01-2014, 02:57 PM Thread Starter
Ya no everything is tight, its not loose. I have checked that. Its sounds like fluid making the noise.
wreedPS is offline
post #7 of 16 Old 01-01-2014, 03:01 PM
Quoted: 3 Post(s)
I figured you did. I have to say, this is first time I've heard of this. That's what your going to hear If you take it in to the stealership. Hope ya figure it out and let us know.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #8 of 16 Old 01-01-2014, 03:02 PM Thread Starter
Ya im not gonna take it to the dealer. I will fix it myself. Ill replace the damn line myself before I let them monkey with it.
wreedPS is offline
post #9 of 16 Old 01-01-2014, 03:05 PM
Quoted: 3 Post(s)
Good idea! By the time they get done with it, your gonna need a new cooler and God knows what else! Plus when you work on it yourself you learn more about your Truck.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #10 of 16 Old 01-05-2014, 09:33 AM Thread Starter
Hey man I found a bolt up the cooler lines on the block of the motor that needed to be snugged down.
No more noise so far!
wreedPS is offline
