Batteries dying - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
post #1 of 5 Old 10-11-2013, 12:29 PM Thread Starter
Batteries dying
What do you make of this?
Tech Comments BAD BBATTERIES BATTERY 1 DTC CODE 14QJR WHBS0 980 ACE CODE XE76P BATTERY 2 DTC CODE 1 TOW IN NO START, DISCONNECT BOTH BATTERIES AND PERFORM BATTERY TEST ON EASCH BATTERY. BATTERY 1 11.95V 384 CCA BATTERY 2 12.05V AND 448 CCA, REPLACE BOTH BATTERIES PERFORM CHARGING TEST WITH NEW BATTERIES INSTALLED CHARGING 13.0 VOLTS AND 80 AMPS OK. ROADTEST OK
And again...
MODULES NOT GOING INTO SLEEP MODE VERIFY CUSTOMER CONCERN BATTERIES TOTALLY DEAD. CHARGE BOTH BATTERIES AND TEST FOR AMPERAGE DRAW .08A DRAW REMOVE EACH FUSE ONE BY ONE TO ISOLATE AMPERAGE DRAW CIRCUIT COULD NOT ISOLATE CIRCUIT BY REMOVING FUSES. RECALIBRATE BODY CONTROL MODULE WITH UP TO DATE CALIBRATION AND RETEST TRUCK SAT FOR 4 DAYS AND BATTERIES STAYED CHARGED WITH NO
Slow crank.
CK FOR A DRAW NONE FOUND ,CK OASIS ,NO HELP,UPDATE PCM,TCM ,NOX ,GPCM , TEST DRIVE FOR ANY PROBLEMS ALL OK
Targo is offline
post #2 of 5 Old 10-22-2013, 05:39 PM
late_99_PSD's Avatar
Quoted: 10 Post(s)
We had a truck at work that had a dead cell in it (checked with a hydrometer) and wouldn't hardly start. Just replaced the battery and good to go.
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
post #3 of 5 Old 10-22-2013, 05:44 PM
Lilfarmrboy's Avatar
I got a 6.0 that will drain my batteries when I would let her sit for more than 4 days at a time. Still have not figured it out. Even went as far as getting 2 new batteries from Advance Auto Parts with the same result. Starting to wonder if my FCIM is causing it.
Lilfarmrboy is offline
post #4 of 5 Old 10-23-2013, 05:22 PM
And again...
Slow crank.
Is this on a C&C truck?..
We have had this issue out of several of our service trucks. Initially thought it was something on the service body. Finally realized some of the modules in the truck fail to go into sleep "reduced power" mode. Dealerships have messed with them some, and have had some success.
poormanscat is offline
post #5 of 5 Old 11-22-2013, 07:44 PM
Quoted: 158 Post(s)
a couple guys have found bad/intermittent alternator regulators killing batteries. in one case the field was staying energized
2005 F350 srw Crewcab lariat. 6.0 diesel aka Sherman
Carstairs Alberta
nitrogen is offline
