Starting system failure with key but not auto start - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
post #1 of 6 Old 09-07-2013, 01:12 PM Thread Starter
Exclamation Starting system failure with key but not auto start
2011 lariat Starts with auto start but then shuts off and alarm goes off when key is put in and turned? Anyone got any ideas or nightmares to share? It's a pretty lawn ornament but would look better going down the road
akcarmichael13 is offline
post #2 of 6 Old 09-07-2013, 01:17 PM
jesilvas's Avatar
Sounds like they key isn't programmed to the truck if that's possible. It's a lawn ornament; so you can't even start it at all?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 09-07-2013, 01:20 PM Thread Starter
It starts with auto start but soon as you insert then turn either one if the keys it shuts off and horn starts honking in alarm. Did it once yesterday n
Then when I opened door while running it said "insert key to stop alarm" n that fixed it but today neither key will start nor allow to
Continue past auto start start. It's like the keys are no longer programmed or something
post #4 of 6 Old 09-08-2013, 01:08 PM Thread Starter
2011 6.7 starting problem update
Truck would start with auto start but not with key indicating starting system failure and security alarm would go off. Son in-law is ford diesel mechanic n had seen it one time before. Turns out the truck security was reading chip in FOCUS key on ring instead of the lariat key in ignition. Thus after couple tries with key it would go into lockout mode. Pulled FORD FOCUS key OFF ring and truck's starting fine.
post #5 of 6 Old 09-08-2013, 01:47 PM
jesilvas's Avatar
So the key was just too close. Dumb haha
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 6 Old 09-08-2013, 05:47 PM
Quoted: 2 Post(s)
Did you get it working yet?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
Tags
