2012 f-250 secondary cooling resivor - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
User Tag List
post #1 of 5 Old 06-27-2013, 10:30 PM Thread Starter
I have a 2012 f-250. the secondary cooling reservoir continues to lose coolant. No signs of any external coolant leak. I have added about 1/2 gallon since issue started. Dealer has no idea what is wrong/where coolant is going. Anyone have this problem, help would be great. Thanks.
tj5617 is offline
post #2 of 5 Old 07-07-2013, 05:47 PM
2013F250Tank's Avatar
Crack in EGR cooler?
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #3 of 5 Old 07-08-2013, 04:33 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 5 Old 07-08-2013, 10:23 AM Thread Starter
2012 EGR cooler leak
Yes, when tech at the dealer removed the EGR cooler he found a small area where he believes the cooler was leaking coolant. The tech said he was not 100% satisfied that is the entire problem. A new cooler was installed and we will see if I still lose coolant.
tj5617 is offline
post #5 of 5 Old 07-11-2013, 05:55 PM
I would second the EGR cooler if there are no external leaks.
poormanscat is offline
