OH NO, my new F-250 is starting to have "issues"!! - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
post #1 of 15 Old 04-05-2013, 07:56 AM Thread Starter
Trem720's Avatar
Bought a leftover 2011 F-250 Lariat 6.7 last spring brand new, its got about 10k miles now and up until about 8k miles was amazing, great power, mileage, acceleration, it made my 12v cummins really seem like a tractor. Anway, at about 8k, it started feeling like it wa in tow haul mode all the time (and i do not do any heavy towing), the clutch fan seems to run wide open (Sounds like a jet engine, the mileage is dropping around 2-3 mpg. The tranny doesn't feel like it shifts hard, it just feels like its holding itself in gear too long, and the fact that the once quiet motor now sounds like a jet turbine when you take off is kind of concerning. Took it to the dealer this week, no error codes, but I told them this is NOT the same truck I bought a year ago. They said it's not going to drive like it did when you got it! Now how would any truck owner take that, what kind of answer is that? Has anyone had any symptoms like mine, or have any recommendations on what it could be? Thanks.
Trem720 is offline
post #2 of 15 Old 04-05-2013, 07:59 AM
That's sh*tty. Mileage should increase as the motor breaks in. I'd find a different dealer.
Moto2four is offline
post #3 of 15 Old 04-05-2013, 10:14 AM Thread Starter
Trem720's Avatar
Just a thought, but could it be a defective clutch fan? If the clutch is binding, the fan may not release causing excessive cooling and noise, especially at highway speeds, plus that would rob some power and a fan that runs under resistance or all the time would eat mileage too?
Trem720 is offline
post #4 of 15 Old 04-05-2013, 07:39 PM
ya my mileage is 4 miles less than my dads we r both deleted im out of warranty but im thinking you and I are having the same problem fan clutch hung up or something
]2011 f250 king ranch cc/sb fx4 black and tan allot of inferior parts fell off so i put better ones on . 5inch exhaust axle dump s7b intake . blistien 5100s all the around . 20x12s on 305,55,20s .leveling kit with bags in the rear .5% tint all the way around
lhood6.7 is offline
post #5 of 15 Old 04-08-2013, 07:35 PM
ok... you are gonna think this is crazy, but my 2011 F550 did the same thing.. it was the high pressure switch in the a/c system. It kept sending faulty signals to the ecu/ecm, thinking the pressure was excessive, so it would constantly engage the fan clutch to try and cool the refrigerant down.. Finally got to the point the a/c would not engage
poormanscat is offline
post #6 of 15 Old 04-08-2013, 07:46 PM
was it throwing any kind of codes , were is this sensor located , and what did they do to pin point this
lhood6.7 is offline
post #7 of 15 Old 04-09-2013, 05:26 PM
same question as above.
I've been thinking that my fan clutch was going bad after noticing that it seems to be on constantly. Even when i start the truck in the morning the fan seems to be on which doesn't sound right..
My mileage dropped down to 16mpg overall and i'm deleted.
2012 F-350 supercab long bed srw lariat tuxedo black
MBRP 5" dp-back exhaust (thermal coated) with RBP 6" tip, AFE pro-dry s cold air intake, H&S mini maxx, H&S EGR delete, RBP rx3 nerf bars, RBP fender emblems, RBP rx2 grille with color matched grille surround, AMI color matched locking fuel lid
Soon to install..
RBP rear bumper, RBP front winch bumper w/ Warn 16.5ti, Icon 4.5" stage 3 suspension, Icon steering stabilizer/shocks, 35"x12.5" nitto trail grapplers, RBP Revolver 20" wheels
theinfamouskonrad is offline
post #8 of 15 Old 04-09-2013, 08:30 PM
one more week and i will be able to go to a dealer and dig for a for sure answer . this fan deal is pissing me off
lhood6.7 is offline
post #9 of 15 Old 04-10-2013, 02:25 PM
I drive an F550, so they are used to us complaining about them being gutless and consuming fuel like a crackhead buying Sudafed..
The Fan clutch started engaging wheile travelling down highways at 70 mph... it was already getting hot outside, so at first, I didnt think too much about it... after a couple months it got to the point where it was disengaging the a/c compressor and the fan clutch started running almost all the time... I checked the system for freon level, it was ok.... took it in to the dealership, at first, they were thinking the fan clutch was out, but while talking to the tech, i mentioned that the a/c system disengaging and the fan clutch roaring seemed to be happening together.....
According to him, the high pressure switch/sensor reports back to the ECU/ECM/PCM.... (whatever its called) and can control the clutch based on high side readings.... sensor was faulty and telling controller the pressure was too high, controller locked up the fan clutch in an effort to cool the refrigerant down and decrease pressure.
Thats how it was explained to me anyway... All I know is the a/c works great and the fan rarely comes on...
post #10 of 15 Old 04-10-2013, 03:26 PM
thats strange but make since . ill be home Monday if Chesapeake stays with there plan lol . when i go the dealer ill keep this in mind was all this work under done under warranty.
lhood6.7 is offline
