Cooling fan issues?? - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
Old 03-29-2012, 05:52 PM
hi guys. I have a 2011 6.7 with 18000 miles, the cooling fan is on every time i start it and when i drive off it roars for a min then goes off. Then every time i stop for more then a min it is back on and does the same thing. so annoying. Ford put a new clutch fan and same thing. anyone else have this problem. Thanks.
Old 04-15-2012, 04:26 AM
any possibility you have the AC or defrost selected. that will cause the fan to come on for the AC system
Old 04-15-2012, 07:19 AM
Is it possible they installed a fan clutch meant for a truck with a plow option? I believe these draw more air in at low RPM's
Old 04-15-2012, 10:35 AM
Shouldn't matter whether its for a plow model. It should still only come on when one of several heat parameters is high
Old 04-15-2012, 10:37 AM
There was another thread exactly like this.
I think it was leaning toward "morning sickness" like the 7.3s have cause of the viscous fan clutch.
Old 05-03-2012, 08:45 AM
Replaced mine...same thing.
Old 05-03-2012, 04:03 PM
If a new one does then exact same thing then it sounds normal to me.
Old 05-05-2012, 05:30 PM
I had mine replaced, it does NOT come on now, even when pulling hard...
Old 05-05-2012, 05:52 PM
If it aint a CAT itsa DOG
I noticed mine does this after the initial startup. I will have to pay attention to whether it comes on after sitting for a while. Basically acts just like my 7.3 did. Mine is a 2012 with 450 miles on it.
Old 05-07-2012, 04:42 AM
Taking mine in this morning to have this issue checked out!!!
