| 6.7 Problems Forum 6.7 Problems Forum |
Wow. I've never heard of anything like that without using some sort of starting aid.
that was my first thought, so i was sniffin around like a blood hound but i couldnt find or smell any evidence of starting fluid or anything, there was a moderate oil residue in the cac tube from the intercooler. this truck sees a lot of idle time and has 28000 on the ticker, i replaced the egr cooler a while back for a p0401 code and found the coolers cacked full of "carbon"
Wow! That was a hell of a pop
Hmmmmmm and the oil pan is plastic too.
Are you implying that this wouldn't have happened if the intake manifold were made of cast aluminum? Regardless of what materials the parts are made of, the truck obviously had something go seriously wrong. I haven't heard of anyone damaging their oil pan just because it's plastic. Actually, plastic has more memory than aluminum or steel. It can return to it's original shape after an impact.
+1 for plastic being good for manifolds and pans.
well at this point, the oil pan is intact and did not suffer from the engine falier the destroyed the intake. all i saw with the borescope was heavy scoring on the #2 cyl wall, talking with ford hotline at the moment to see what they want me to do...
correct me if im wrong but i would think that metal would be effected by -35 C more than a composit plastic. i know that metal expands/contracts a lot with temp change.
