2011 Natural Pull to the Right - Ford Powerstroke Diesel Forum
6.7 Problems Forum 6.7 Problems Forum
Old 07-10-2010, 11:25 AM
Just wondering if the 2011 F250 6.7 has a natural pull to the right.
am I the one with the "Beta" lemon ?
Old 07-10-2010, 11:28 AM
Illiana Chapter Director
The one I drove didn't pull. Take it to the dealer and have them check the alignment and if it's ok have them switch the 2 front tires side to side and see if the truck pulls left. If it pulls left, you have a radial pull which can be corrected with a new tire.
Old 07-10-2010, 04:44 PM
Thanks for the reply, the truck is headed back to the dealer in a couple of weeks.
Old 07-10-2010, 04:52 PM
shaking things up
it could have gotten miss alligned on the transport truck or something stupid like that just have em check ya out
Old 07-10-2010, 05:46 PM
Mine had a pull to rite after i rotated the tires back to front. Rotated tires back & pull went away. Took it to dealer & they rotated tires back to front & rite to left. Also did a balance first on all tires, service manger test drove after every change & said the steering wheel was off a little to the rite. Finally put on wheel alignment machine & checked said both sides were same according to machine spec. Finally installed a shim in rite side & it fixed the problem for now...
Old 07-10-2010, 05:48 PM
I'm hoping it's a simple fix. Overall, I like the truck very much, it's all the little quarks I'm finding that's starting to get aggravating, I.E. wind noise whistleing coming from the driver's door window, the alignment, and the rattling coming from above the headliner in the sunroof components.
All of which the dealer will be taking care of in a couple of weeks.
I just hope these will be the only issues I have with the truck.
Will
Old 07-10-2010, 06:07 PM
Mine presently has the pull to the right, the dealer has already tried once to re-align the truck, however their alignment computer did not have the 2011 programming yet, so they tried based on 2010 programming......they said the truck fell within specs.
Initially, along with the pull to the right, the steering wheel was also offset to the right a little, and after the dealer tried the first time to align the truck, they rotated the front tires and re-aligned it. The truck fell within specs, based on 2010 programming, but still pulls to the right, only now the steering wheel is offset to the left the same distance as it was when offset to the right.
After the alignment. took the truck for a test drive, initially appeared ok, but the roads are crowned pretty bad, so I accepted the truck. When I got the truck back on the interstate, on a good flat patch, that's when I noticed the truck still had the pull to the right and the steering wheel was offset to the left this time. So the truck is headed back in couple of weeks for another attempt at re-alignment.
Old 07-10-2010, 08:04 PM
6.4 owner chiming in....
My new 2010 pulled to the right.....dealer checked it out and determined she was out of spec.
She tracks so true now, I could take a nap in the back while driving through west Texas!
Old 07-11-2010, 08:50 PM
Mine pulled the right, had to pull a Prius out of the front right brake caliper....
Old 07-12-2010, 05:50 PM
no pull on mine
