6.7 problems - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 1 Old 03-04-2014, 05:10 PM Thread Starter
6.7 problems
hi I have just bought a 2011 f250 6.7 I am getting a hill descent fault coming up on the display screen and traction control light is flashing also my 4x4 will not shift it says shift delayed pull forward the abs light was on I replaced the right rear wheel speed sensor that showed bad I have the auto enginuity ford bundle and this is the codes I pulled up Body control module 14229 cose is B124D unknown trouble code description. the KOEO says test failed unknown error, KAM memory reset says same thing any help that you have will be appreciated thanks
mack82 is offline
