ABS Module communication errors - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 8 Old 02-08-2014, 12:49 PM Thread Starter
jacobdewey's Avatar
I had a code pop up, something about ABS module communication error, and also something about CAN BUS.
My truck started chiming, and the speedometer was jumping all over the place. The traction control kept turning of and on. It did it twice in a row after restarts, then finally quit and threw those two engine codes. Anybody have a similar problem? The fix?
2011 CCSB, 20x9 -12mm Badlands, H&S, S&B, Katzkin, DDM 5k, 4" Zone, 37x12.50r20 Nitto Ridge Grapplers.
jacobdewey is offline
post #2 of 8 Old 02-11-2014, 08:31 AM Thread Starter
jacobdewey's Avatar
Bump....ttt
post #3 of 8 Old 02-11-2014, 08:43 AM
Heavy_GD's Avatar
Quoted: 1656 Post(s)
Feedback Score: 3 reviews
It sounds similar to a failing speed sensor in the rear diff on the 6.0
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #4 of 8 Old 02-11-2014, 04:46 PM
Bryce18's Avatar
Quoted: 19 Post(s)
Symptoms point to bad VSS (vehicle speed sensor) in rear end.
This sensor controls speedometer, abs, traction control etc. Could be bad sensor or faulty connection.
I have replaced this sensor on OBS 7.3L powerstrokes but haven't heard of any on the 6.7L going bad yet. Take to dealer.
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #5 of 8 Old 02-11-2014, 04:53 PM
Bryce18's Avatar
Quoted: 19 Post(s)
Check this out.
Here is the sensor and wiring harness.
But you should only need sensor
http://www.fordparts.com/Commerce/Ca...=1&keyword=VSS
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #6 of 8 Old 02-12-2014, 02:11 PM Thread Starter
jacobdewey's Avatar
Thanks. I'll check it out.
The Following User Says Thank You to jacobdewey For This Useful Post:
Heavy_GD (02-12-2014)
post #7 of 8 Old 02-12-2014, 03:26 PM
Heavy_GD's Avatar
I've read anywhere from chaffed wires, to water in he plug, to people pulling and cleaning the sensor as cheap fixes before replacing it
GD
...because Patriot.
Heavy_GD is offline
post #8 of 8 Old 08-07-2014, 04:40 PM
L-Force's Avatar
So was it the sensor? My 2011 just experienced the same problem on my way home. Thanks
11 F-250 Loaded, 6" BDS Lift, 20x10 BMFs, 37x1350R20 Terrain Grapplers, Mini Maxx, 4" Flo-pro DOC/DPF Delete.
L-Force is offline
