Please Help: CEL P007E?? - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 5 Old 01-22-2014, 03:20 AM Thread Starter
colecoop56's Avatar
I haven't been on in a while because I have been so busy with work, but lately since it has been cold my truck will throw this code. When I check the code on the Mini Max it says "Charge Air Cooler Temperature Sensor Intermittant/ Erractic". Has anyone else had this issuse? My truck has been flawless until this issue. It only comes on every now in then. I ordered a new Intake air temperature sensor thinking I just need to replace mine and after the install last night the code came on this morning driving to work.
I am deleted by the way so I am not sure what the hell is going on but I hope someone can help.
Thanks,
Cole
colecoop56 is offline
post #2 of 5 Old 01-22-2014, 04:30 AM
HighHP's Avatar
See if you can find a way to monitor the sensor and see what exactly its doing when it throws this code.
2013 - F350 CCLB. - 40" Lift on 40s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #3 of 5 Old 01-22-2014, 04:31 AM Thread Starter
colecoop56's Avatar
How could I monitor it?
post #4 of 5 Old 01-22-2014, 08:07 AM
HighHP's Avatar
Edge CTS, I will check mine after work and see if you can monitor that sensor with it.
HighHP is offline
post #5 of 5 Old 01-22-2014, 04:22 PM
If your truck is a 13, it was something ford changed around a little and has become more sensitive with the newer deleted trucks and will pop up every now and then. If its a 2012 then it will only happen a couple times total. But H&S came out with an update to stop the code from ever popping up
2008 F-250 6.4 leveled *SOLD*
-DPF Delete
-H&S XRT Pro (Mild tuning)
-K&N Cold air intake
-20" KMC Monsters w/ 33" Toyo Open Country M/T
2013 F-250 6.7L "Scorpion" *SOLD*
-5" DPF delete
-H&S Mini Maxx Race Tuner
-2.5" leveling kit
-20" KMC Monster w/ 33" Toyo Open Country M/T
-S&B CAI
-Sinister EGR Delete plus pyro
6.4PowerstokeJL is offline
