Unknown Clunk - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 21 Old 01-10-2014, 10:57 AM Thread Starter
BigGreen06's Avatar
Quoted: 100 Post(s)
Angry Unknown Clunk
Recently, within the past 2 weeks, I've started to hear this thump or clunk underneath the front passenger compartment, specifically under the driver side to middle. I can also feel it in the floor. At first it was occasional, but now it happens each time a make a moderate to hard turn, left or right. I'm thinking it is the steering linkage.
If anyone has any thoughts please help, my truck only has 2700 miles on it.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is offline
post #2 of 21 Old 01-12-2014, 09:51 AM
I had that same clunk and couldn't figure it out UNTIL I removed my factory steering stabilizer shock.
2012 F-350 supercab long bed srw lariat tuxedo black
MBRP 5" dp-back exhaust (thermal coated) with RBP 6" tip, AFE pro-dry s cold air intake, H&S mini maxx, H&S EGR delete, RBP rx3 nerf bars, RBP fender emblems, RBP rx2 grille with color matched grille surround, AMI color matched locking fuel lid
Soon to install..
RBP rear bumper, RBP front winch bumper w/ Warn 16.5ti, Icon 4.5" stage 3 suspension, Icon steering stabilizer/shocks, 35"x12.5" nitto trail grapplers, RBP Revolver 20" wheels
theinfamouskonrad is offline
post #3 of 21 Old 01-20-2014, 03:01 PM
Quoted: 2 Post(s)
Did you ever figure it out?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #4 of 21 Old 01-20-2014, 09:12 PM Thread Starter
BigGreen06's Avatar
Quoted: 100 Post(s)
Still working on it. Dealer said everything looked good, but started getting the sound again.
Accufab Elbow
LineX in the Bed
post #5 of 21 Old 01-20-2014, 11:23 PM
Quoted: 2 Post(s)
loosen and re torque the body mounts.
wreedPS is offline
post #6 of 21 Old 01-20-2014, 11:32 PM
troykimber's Avatar
yup, if the cab mount bolts have any crud on them and they are not fully seated when torque is achieved. then the floor will knock when turning the opposite way.
easy fix if that is what u have going on...
95 sc lb 4x4 5 speed
ts 6 position chip, boost relief valve, 4" intake, 3" downpipe-5" rest of the way to a stack, fpr shim, twin 16" s-blade electric fans, poly bushings, zoom variable torque ceramic clutch with solid flywheel, hydroboost, stancor relay, exhaust brake, ss hpx line, 140v idm, bar and plate intercooler, glowshift gauges, gt grant signature series wheel with black billet hub, rockford door speakers- pioneer head unit- 2x 12" kenwood w3 subs
troykimber is offline
post #7 of 21 Old 01-21-2014, 11:39 AM Thread Starter
BigGreen06's Avatar
Quoted: 100 Post(s)
I'll talk to the srvc manager on thursday when I go back in.
Accufab Elbow
LineX in the Bed
post #8 of 21 Old 01-21-2014, 04:53 PM
DSL_PWR's Avatar
Quoted: 9 Post(s)
^this.
My '10 and '12 had this issue.
DSL_PWR is offline
post #9 of 21 Old 01-21-2014, 06:16 PM
Quoted: 2 Post(s)
Ya man, my 06 Duramax's body mounts were so bad, when I removed them they were almost deteriorated, I put Energy suspension mounts in and honestly that was the best upgrade to improve the ride quality I could do. They were only 3 to 4 years old also.
It was fairly cheap too..
Might look into those for this truck, but I currently have no noises. My 250 is solid as a rock.
wreedPS is offline
post #10 of 21 Old 01-23-2014, 05:25 AM
Sounds like a loose track bar to me because it just happened to me and I felt the same noise and clunk you have described.
http://www.powerstroke.org/forum/gen...r-problem.html
Lrn5000 is offline
