How many of you have had to replace dpf? - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 4 Old 12-28-2013, 02:18 PM Thread Starter
Quoted: 5 Post(s)
So I'm in the market for a used 2011+ (focusing on 2012), F250 or F350 cc 4wd srw and am concerned about all the new emission components on these trucks. After reading horror stories about trucks having issues and being immobile due to exhaust sensors and dpf's, I'm second guessing my decision.
So how common is the need to replace the dpf? It doesn't seem like it is covered under warranty either.
I also realize that reading the issues on this forum only represent a handful of trucks and I'm sure there are thousands of trucks that don't have issues. I plan on using it as a daily driver and to tow a 10k toy hauler.
Thanks!!
DJM7.3 is offline
post #2 of 4 Old 12-28-2013, 03:31 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Buy the '13 or newer 6.7L! The '12's still had some issues Ford hadn't addressed. You will start to see more and more used '13's appear.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 4 Old 12-29-2013, 09:50 AM Thread Starter
Quoted: 5 Post(s)
Thanks for the input. I'll start checking out the 2013s. Were there many changes between the 2012 and 2013? I don't want to pass up a good deal if a used 2012 pops up? Seems like dealers and individuals want high dollar for used 2012 and 2013s, almost what you could get a new one for.
Thanks again
DJM7.3 is offline
post #4 of 4 Old 01-12-2014, 06:50 PM
Quoted: 2 Post(s)
I dont think there is anything major to worry about with the dpf. The Def is kinda a PITA though.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
