Whining or moaning noise - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 5 Old 09-26-2013, 04:11 PM Thread Starter
Blackie13's Avatar
I just recently noticed about 2 minutes after I shut my truck down a moan noise starts to develope and goes on for about 3 minutes. The sound seems to come from the rear of the valley near the turbo. I'm guessing its electrical because the truck is off. anybody experience this and get a diagnosis.
Blackie13 is offline
post #2 of 5 Old 10-04-2013, 01:46 PM
I wonder if these 6.7L trucks have a auxiliary electric coolant pump that runs after the truck is shut off if the turbo is too hot. I had a 1987 Porsche 944 Turbo that did, and it was to cool off the turbo after shutdown to prevent the bearings from burning the oil and coking up. I haven't paid that close attention on my 6.7L, have only had it a week but it doesn't make any obvious noises after shutdown from inside the cab.
Greg
hammong is offline
post #3 of 5 Old 10-11-2013, 09:05 AM
daystrom's Avatar
Quoted: 8 Post(s)
On my truck after shutting it down I hear the DEF purge pump running for about 30 seconds but it is under the cab near the DFCM.
2012 F-350 Lariat 4x4 6.7 PSD
Platinum metallic / adobe accent
"Sir Topham Hatt thinks I need to learn. He is mistaken. We Diesels don't need to learn, we know everything. We come to a yard and improve it. We are revolutionary!"
daystrom is offline
post #4 of 5 Old 10-19-2013, 12:37 PM
1stnlast59's Avatar
A guy I know just had his at the dealership for a a noise after the truck was shut down. I told him about the def pump and he said it was under the hood. They told him it was a harness or something and it was as a result of to much idling. Can't believe u can't idle these trucks like diesels are known for
1stnlast59 is offline
post #5 of 5 Old 10-19-2013, 01:03 PM
Extended idling has never been good for diesels, even back in the olden days (pre-EPA mandates) extended idling would cause diesel to wash down into the oil. The only reason to idle a truck now would be to keep the cab warmed up when it's -30 degrees outside or if you have a PTO and need to use it while the truck is stationary.
I shut mine down any time I expect to be sitting more than 3-4 minutes.
Greg
hammong is offline
