2011 built in 2010 throwing rod??? - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 11 Old 09-16-2013, 12:08 PM Thread Starter
I just bought a 2011 built in 2010 and was told some of the early build 6.7 in 2010 where throwing rods has any one heard this? Also would it be covered under warranty if mine has tuner dpf and def deletes? Thanks
hart18 is offline
post #2 of 11 Old 09-16-2013, 05:51 PM Thread Starter
Bump. Don't want to pay 11k for rebuild
hart18 is offline
post #3 of 11 Old 09-16-2013, 05:57 PM
Your warranty is in serious jeporady when you start modifying. I would be much more concerned with exhaust valve failure than connecting rod failure.
poormanscat is offline
post #4 of 11 Old 09-16-2013, 11:33 PM
BIG Laing's Avatar
2 different times in the past, 2 different companies were doing some modifications and high HP tuning when they suffered catastrophic engine failure from bent rods. I believe the problem was all in the tuning, as I have not seen any rod issues since.
And if you tune/delete, you are kissing your power train warranty goodbye.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 11 Old 09-16-2013, 11:34 PM
BIG Laing's Avatar
List of concerns on 11's and early 12's is turbo then valves.
post #6 of 11 Old 09-17-2013, 11:34 AM
Some of the very early build 1 F-450's did have a few throw rods. Haven't heard of any in 350 and below (differant engine tunes and turbos)
2011 F-350 CC LB SRW Larriet 6.7 PSD with a limited edition rear end bounce @ 43 mph.
thom12 is offline
post #7 of 11 Old 09-22-2013, 08:26 PM
Bryce18's Avatar
Quoted: 19 Post(s)
Like said above. I don't think bent rods are an issue for stock.
From what I've read is bent rods in the f250 and 350s occurs when massive amount of bottom end torque is added. Such as compound turbos.
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #8 of 11 Old 09-25-2013, 07:21 AM
My January 2011 build F350 6.7 just came out of the shop with a brand new long block from Ford. Exhaust valve failure caused catastrophic failure to crank shaft, cylinders and pistons. Blew right through the oil pan. I had 36,600 easy drive to work miles on it. So it's not just the 450/550. Don't believe that for a second.
aquasport17 is offline
post #9 of 11 Old 09-26-2013, 04:08 PM
exactly.. its all of them.
post #10 of 11 Old 09-26-2013, 05:58 PM
LFD132's Avatar
Quoted: 3 Post(s)
That's B.S. i was was hoping they would eventually upgrade the rods in these engine. Apparently not.
Sent from AutoGuide.com App
[SIGPIC][SIGPIC]2013 F250 FX4
LFD132 is offline
