White smoke at take off - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 3 Old 09-05-2013, 05:49 PM Thread Starter
Hey guys, in need of a little help here. So I just bought a 2004 F-250 with the 6.0 today. I test drove it and hooked it up to my Edge Insight and did not find any problems with it whatsoever. On my way home, which is about an hour away, once I got in traffic I noticed that the truck started blowing white smoke. It was only doing it when I would take off from red lights. It wouldn't do it that I could see while idling. It also never did it when I was in traffic while I was test driving it. It does not do it once up to speed at all, even if I dump it WOT. My Edge Insight is not reading any DTCs. I swiped my finger around the exhaust and it was not wet, only black soot. I'm just trying to figure out if this is something serious or something that will not be too costly to fix or what. It's not a Ford dealer that I bought it from so they wouldn't be able to fix it. But if it's something bad then I will probably try to take it back. Thanks for your help!!
Tx2va07 is offline
post #2 of 3 Old 09-05-2013, 06:06 PM
Quoted: 2 Post(s)
You posted this in the 6.7l diesel forums. You might want to put this in the 6.0l diesel forums. You will get better responses.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #3 of 3 Old 09-05-2013, 06:11 PM Thread Starter
Crap, thanks! Is there a way I can delete this?
Tx2va07 is offline
