Transfer flow tank removal from 2011 F350 - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 1 Old 08-18-2013, 07:42 AM Thread Starter
RamAirfreak98ss's Avatar
Quoted: 4 Post(s)
Garage
I removed a transfer flow 75 gallon tank that had a trax II controller hooked up. It comes with a harness kit, solenoid etc. so it over rides your fuel gauge in the dash to compensate for having the additional 75 gallon tank too.
When we removed it, i couldn't find where the original fuel harness under the truck was spliced into. We cut the transfer flow harness before it went into the factory wires, "3 wires" which i found in the manual where to hook up , but apparently, one of the wires in the original harness must have been cut to be bypassed, because i taped off the three wire ends but now the fuel gauge doesn't work, truck says low fuel... when its full, so we need that wire lol. Anyone ever install one of these? It appeared the transfer flow wires ran to the top of the fuel tank so it wasn't like i could see the wires where they were spliced or bypassed so i could put them back together, "nor did i think an original wire was cut".
04 F350 XL
06 F350 Lariat SRW BPD oil cooler, ARP, sinister !egr, s&b intake
06 F350 Lariat C/C DRW 4" Silverline , BPD egr cooler, ARP studs, Garett powermax turbo
07 F550 XL c/c 12' ABC american landscaper
11 F350 Lariat C/C !dpf/doc, SCT 7015
14 F550 Lariat C/C Dump truck, !def/dpf, Flo-Pro, T1 Tuner, S&B intake 3200miles
16 F350 Lariat c/c Nov 2015
RamAirfreak98ss is offline
