Radiator leak - just out of 36k warranty - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 30 Old 07-17-2013, 06:25 PM Thread Starter
daystrom's Avatar
Quoted: 8 Post(s)
New to me '12 F350 Lariat w/6.7 PSD. Clock has 36,500 miles.
Just out of the bumper to bumper warranty.
Noticed a coolant leak under the front driver side of the truck. Radiator is leaking where the plastic tank crimps to the radiator. Looking at the interwebs it looks like this is a very common issue and is about $1600 to replace.
Options? Should I cry to Ford about it failing just outside of the bumper to bumper warranty and see if they cover it? Should I buy a Ford ESP warranty before it is too late and turn it in to it?
Ugggghh.
2012 F-350 Lariat 4x4 6.7 PSD
Platinum metallic / adobe accent
"Sir Topham Hatt thinks I need to learn. He is mistaken. We Diesels don't need to learn, we know everything. We come to a yard and improve it. We are revolutionary!"
daystrom is offline
post #2 of 30 Old 07-17-2013, 06:51 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 275 Post(s)
Well it is very common on 6.4 trucks but I haven't heard anything about the 6.7's leaking.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #3 of 30 Old 07-17-2013, 08:24 PM
Unfortunately it has been a problem since 2008 with the advent of the plastic/metal radiators. The 6.7 apparently has the same issues. Many folks on the forums have encountered the same thing. Mine went out at 51K and Ford fixed it as if I had the extended warranty and had me pay the $100 deductible. I decided after that to buy the out of warranty ESP option for an additional 75K miles or 5 years from date of purchase for the highest level of coverage. Bout $3K for the ESP but I will not worry about these issues again for quite some time. Hope it works out for you.
jriltex is offline
post #4 of 30 Old 07-17-2013, 10:55 PM
WD40's Avatar
Quoted: 31 Post(s)
I sure would ask them to fix it, all they can say is no. Then go to another dealer
and buy the warranty or buy it on line.
Doug
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #5 of 30 Old 07-18-2013, 07:24 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
This is the 1st time I've ever heard of the 6.7's having radiator issues.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 30 Old 07-18-2013, 09:55 AM
Stroker, there have been many many references to this on the various Ford 6.7 forum sites. And they are ALL in the same place. the seal between the plastic and the metal on the drivers side at the bottom corner. I inspected mine with a computer magnifying gizmo and the crimped metal tab holding the plastic and metal together where mine was leaking actually had lateral stress cracks running the length of it, which I assume allowed the clamp to flex with the truck movement and eventually began leaking. Small drops at first but over time it lower the radiator level. There was a fix I saw where you could rebend the tab using a pair of vice grips and setting it to clamp securely on a drill bit to get the right squeezing strength. You can search the forum for that. Seems all this is is a rubber gasket between the rubber and the metal being squeezed together by bending the little tabs over. I hear Ford gets compensated by the radiator manufacturer when one goes out in warranty so no urgency on their part to fix.
jriltex is offline
post #7 of 30 Old 07-18-2013, 10:15 AM
If you bought the truck from a dealership, I would try them first and see if they will make good on it.
Unfortunately, the radiator problem is a very common issue. Would be interesting to know if the replacement radiators are the same part # or if Ford is making any type of change?
poormanscat is offline
post #8 of 30 Old 07-18-2013, 10:34 AM
Quoted: 275 Post(s)
Obviously they are not making any type of change since they've been doing it since 2008
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #9 of 30 Old 07-18-2013, 10:38 AM
ZMANN's Avatar
Quoted: 1463 Post(s)
just to through it out there the 6.0's also have the same style radiators as do many other vehicles without a large history of issues
this may just be a design issue where the mounting puts to much stress on the tank joints ?
however I haven't seen a ton of complaints with the 6.7 ? to new?? IDK
I replaced my plastic tanked radiator at 90,000 just for PM and went to an all aluminum Radiator
We Miss you Ronnie
ZMANN is offline
post #10 of 30 Old 07-18-2013, 05:30 PM
all of our 2011 models have had radiators... a couple of the 12 models.. our servicing dealer says they change a couple a week. Next time Im in for service, IICR, I will ask them if there is a p/n change...
