Bad Turbo? - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 5 Old 06-29-2013, 04:15 PM Thread Starter
79_bronco's Avatar
Bad Turbo?
I am throwing code P132B on my truck right now and it is pretty gutless and doesn't seem to be boosting.
The check engine light isn't on and it didn't go into limp mode or anything but is just short on power.
I didn't clear the code and will probably take it to the dealer Monday but was wondering if anyone here has any ideas.
Its bone stock with 4100 miles on it. And the dealer just changed the oil less than 100 miles ago.
2012 F-250 Lariat Crew Cab Short Bed 4x4 FX4
Ranch Hand Front and Rear
30in Rigid E Series Light
Bilstein 5100 Series Shocks
Truck Cover USA American Work Cover with Toolbox
Kenwood DNX570HD Head Unit
79_bronco is offline
post #2 of 5 Old 06-29-2013, 06:41 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 5 Old 07-01-2013, 08:48 AM Thread Starter
79_bronco's Avatar
Bad Turbo?-imageuploadedbyag-free1372693668.633904.jpg Well it's at the dealer now. We will see what happens.
post #4 of 5 Old 07-01-2013, 01:54 PM Thread Starter
79_bronco's Avatar
Well got it to the dealer and apparently they said the code wasn't active when they started looking at it. So I'm going to go pick it up and see how it runs now.
post #5 of 5 Old 07-01-2013, 10:08 PM Thread Starter
79_bronco's Avatar
I got to talk to the dealer and it is working fine now. After talking to a few friends we decided that the waste gate was most likely stuck open somehow. It had a pretty harsh tow truck ride across town and when the hooked it to the computer the code wasn't active anymore and when I got in they had completely cleared it. Not sure what to think but it is running and driving just fine now. I even got on it leaving the parking lot and had no problem getting 20lbs of boost
Anyone else had something similar happen or any other opinions on why I could hear the turbo but never got any boost on the boost gauge?
A few other items to put the story all together....
Friday I took it in for an oil change at the dealer with 4005 miles on the clock. It drove home just fine then Saturday we went trolling around town looking at some used campers. We had stopped at the store after leaving one of the camper places and I turned it off but then remote started it again because I wanted to come back to a nice cool truck (probably like 60 miles after the initial oil change at that point). Got back in and took off down the road and got on the interstate to head home, realized about 5 miles in on the interstate that it was struggling to pass someone, didn't think much of it, then I hit my exit about 10 miles later and really realized it at that point. I was only about 5 miles from home then so I went ahead and drove the rest of the way since the CEL wasn't on. Got home and pulled to code and that's where it sat until Monday morning. Another item is the CEL never actually came on and I didn't go into limp mode or anything either. Just short on power.
