Help! My truck is leaning bad - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 17 Old 05-06-2013, 08:56 AM Thread Starter
I Have a 2011 F250 cc/sb 6.7l
With 8 inches and 36x15.50 mtz's
and for some reason the truck is leaning down on the driver side
almost 2 inches from measurement of tire to fender. even the driver side shock is depressed lower than the passenger side and to be honest I'm completely stumped i have no clue what it is I've check all the springs etc etc taking multiple measurements and its not the fuel tank causing it.
Any insight would greatly be appreciated because as of now im stuck
DieselKingRanch is offline
post #2 of 17 Old 05-08-2013, 04:37 AM
maybe have your wife or girlfriend slide over to the passenger side of the truck?
Rangerpl is offline
post #3 of 17 Old 05-08-2013, 04:52 AM
hahahahahahaha!
btbarnes7 is offline
post #4 of 17 Old 05-29-2013, 10:45 AM
miles97's Avatar
Did you figure it out?
Who installed the lift?
97' F250 7.3 XCSB Standard 203,500 miles
T&S 6 position, Sraight piped, K&N
SOLD
05' F350 6.0 CCSB Auto 155,000 miles
Edge Platnium W/hot, 4" Sidepipes, AFE intake, leveling lift 325/65R18
00' Camaro SS 6-speed standardT-tops 73,000 miles
SLP Airbox SLP loudmouth exhuast custom tuned
73' F100 SCLB Standard ? miles
Built 390, lockers, 7" lift, 35 12.50R15
miles97 is offline
post #5 of 17 Old 06-10-2013, 07:21 PM
i am having the same problem with a 6 inch on 37s except its only 7/8''
pitbike50 is offline
post #6 of 17 Old 09-04-2013, 05:50 AM
1stnlast59's Avatar
My dad just bought a '13 ccsb 4x4. It has 175 miles on it and sits 1" lower on the front drivers side and 1/2" lower on the rear drivers side. Brand new truck. It looks way worse than that if u look at it from the rear. That's why I pulled a tape on it. Urs might have started out like his and the lift just made it worse. Don't know the cause or the solution. Just thought I would tell about his. Haha
1stnlast59 is offline
post #7 of 17 Old 09-04-2013, 07:04 AM
Skyd Ram's Avatar
Quoted: 150 Post(s)
^^^Exactly^^^
I deal with customers all the time that have issues with their trucks being low on the drivers side after installing a lift. In most cases the truck sat low before the kit as there is a lot more weight on the drivers side and they just never noticed it.
Fuel Tank
Fuel
DEF Tank
DEF
Steering column
Steering gear
Etc........
I recently measured every brand new F250/F350 at my local dealer and they were all a minimum of 1/2" low and up to 1" low on the drivers side.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #8 of 17 Old 09-04-2013, 08:54 AM
1stnlast59's Avatar
So would it b safe to say that he could just put a 1/2" bottom spacer on the drivers side to rid it of that problem if someone wanted to or it was bugging them that bad.
post #9 of 17 Old 09-04-2013, 02:13 PM
Skyd Ram's Avatar
Quoted: 150 Post(s)
Yeah,
That would take care of the front. You would also need to do something with the rear in the form of a taller block on one side.
Ironically, I saw a part in the Ford dealer system for a 1" block kit for guys that complain about the factory lean.
888-886-2480
Skyd Ram is offline
post #10 of 17 Old 09-06-2013, 01:15 AM
Mannysouza's Avatar
Quoted: 124 Post(s)
I remember that the ford lift kits would come with one longer spring for some time. It was to compensate for this. Maybe the suspension manufactures don't do this anymore.
Mannysouza is offline
