2012 body mount noise - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 8 Old 02-21-2013, 06:39 PM Thread Starter
If it aint a CAT itsa DOG
dieseldan2005's Avatar
I have been having this horrible popping noise since it got cold out in my truck. It does it whenever there is torque on the frame or body of the truck, can be from turning, braking, or accelerating. Dealer couldn't get it figured out the first time, 2nd time they said body mounts were causing it. I guess there was a tsb for the 09-11 trucks but not the 12's. Anyone else have that noise? You can feel it pop in your floorboard. Supposedly they are shimming it to fix it.
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #2 of 8 Old 03-29-2013, 09:35 PM
F350KR's Avatar
YEA!!! i have the same noise. mostly when i turn corners... i think its the upper pan hard mount to the frame? havent looked. but afraid i should have dealer look before i install my lift
Had- 2004 F350 CC LB 4x4 6.0 Tuned, 4" Straight Pipe, K&N, LED strobes, Double DIN Dash Mod, 201,653 on the OD
Have- 2012 F350 King Ranch CC, H&S, Straight piped, Whited out grill, Readylift sitting in living room...
F350KR is offline
post #3 of 8 Old 03-29-2013, 09:54 PM
BIG Laing's Avatar
I feel a real light "popping" under my feet when I hammer down between shifts...
No noise though, just a feel.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 8 Old 04-07-2013, 04:12 PM
My 2012 has noise/pop also, usually seems to do it when turning, especially when on stud grooved roads. Dealer cannot duplicate either.
Mc907 is offline
post #5 of 8 Old 04-07-2013, 05:02 PM
Same here.
A single "pop" noise right under the drivers feet area. Only happens while turning left fast.
It's really annoying, i was thinking about installing aftermarket urethane sway bar bushings just incase those were the culprit.. but could be anything.
2012 f350 4x4.
2012 F-350 supercab long bed srw lariat tuxedo black
MBRP 5" dp-back exhaust (thermal coated) with RBP 6" tip, AFE pro-dry s cold air intake, H&S mini maxx, H&S EGR delete, RBP rx3 nerf bars, RBP fender emblems, RBP rx2 grille with color matched grille surround, AMI color matched locking fuel lid
Soon to install..
RBP rear bumper, RBP front winch bumper w/ Warn 16.5ti, Icon 4.5" stage 3 suspension, Icon steering stabilizer/shocks, 35"x12.5" nitto trail grapplers, RBP Revolver 20" wheels
theinfamouskonrad is offline
post #6 of 8 Old 04-07-2013, 05:47 PM Thread Starter
Mine did it worse when it was cold out. I ended up selling the truck. After my bumpers started rusting with only 14k on them and ford said they wouldn't cover them i said good by.
Diesel Dan
post #7 of 8 Old 04-19-2013, 05:20 AM
6.7strokin's Avatar
I can feel the a movement/tapping feeling in the floor board of my 12 as well. I have never noticed it in turns or during acceleration but more during coasting on bumpy roads doing less than 50 mph. Interested to see what you all find to be the culprit.
6.7strokin is offline
post #8 of 8 Old 04-23-2013, 10:36 AM
:update on my popping noise under the floorboard:
I fixed my popping type noise under the floorboard while turning..
I had it ever since i owned the truck new. I did add icon steering stabilizers and drove around that way for awhile, and the popping was still there. But totally forgot about removing the factory steering stabilizer which you are supposed to do when adding dual aftermarket stabilizers. After removing that, the popping noise is completely gone! So idk if the factory stabilizer is the culprit, or if that causes the steering gear box to have strain on one side causing the "pop" but you may want to check that out. Or maybe just remove the stabilizer to see if the "pop" goes away.
Soon to install..
