1300-1400 rpm vibration anyone else - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 27 Old 02-15-2013, 03:52 PM Thread Starter
rvdb's Avatar
I asked this in driveline section with no reponse & it's at the dealership for its 3rd visit with Ford MoCo involved. Hi, First off I am new to the site & appreciate any input, I picked up a 2012 F350, 4x4 CC, LB, a month ago and I am in need of help, I searched the site, asked questions on other threads with no luck.
I have a vibration at 1300-1400 RPM roughly in between 35 to 45 miles an hour, I am guessing its driveline related due to how the vibration comes about.
Ford replaced the drive shaft and balanced the exhaust and checked/balanced the tires.
The problem still persist, I was sent out the door per Ford. I have 800 miles on it and really like the truck however I feel this will lead to premature wear of components not to mention when I break it in & start towing 12k lbs.
Questions; has anyone dealt with this, does it get worse or stay the same?
I am very disappointed in this product at the moment, and I am frustrated, thanks for your time.
rvdb is offline
post #2 of 27 Old 02-15-2013, 05:39 PM
is the vibration in the seat or the steering wheel?
poormanscat is offline
post #3 of 27 Old 02-15-2013, 06:32 PM Thread Starter
rvdb's Avatar
It comes through the seat, however it is not easily pinpointed it feels like it comes through the entire truck, I did notice last weekend I put 150 miles on it and the vibration fluctuated, It felt worse a couple of times. Thanks for your time, I feel like any info I can give the dealership/Ford Motor Company would help get this resolved quicker.
rvdb is offline
post #4 of 27 Old 02-16-2013, 04:58 PM
does it shake if you throttle the engine up in neutral while sitting still?
post #5 of 27 Old 02-16-2013, 06:41 PM Thread Starter
rvdb's Avatar
This is why these types of sites are great, poormanscat, I tried numerous things and never thought of that, I will ask the tech on Monday, thanks for the question/suggestion.
rvdb is offline
post #6 of 27 Old 02-26-2013, 12:31 PM
My F350 DRW is doing the same thing and is getting worse. Seems it does it between 1000 - 2000 rpm. Its a moan with a slight vibration and is very annoying. I feel it through the throttle pedal more. Any Clue? Does this in gear and in park.
F350CRAZY is offline
post #7 of 27 Old 02-26-2013, 12:36 PM Thread Starter
rvdb's Avatar
Well Ford still has the truck, it does not vibrate in neutral.
I stopped by yesterday & they had a machine Connected to it that senses the vibrations and the noises as they are driving it. So far they can't pinpoint it. It's disappointing a two month old truck that's been with Ford for one of them.
rvdb is offline
post #8 of 27 Old 02-26-2013, 02:26 PM
RTRBURN's Avatar
I started noticing this week mine doing the same thing. I bought it used with 30k and have had it 1 month. It's almost like your going over a washboarded gravel road then it goes away once you speed up. But doesnt do it every time.
2011 Silver F250 Lariat CCSB 4x4 6.7 H&S Deleted (mine)
2012 Burgundy F350 Lariat CCSB FX4 6.7 (wifes)
RTRBURN is offline
post #9 of 27 Old 02-27-2013, 08:52 AM Thread Starter
rvdb's Avatar
F350CRAZY, no clues till yesterday, Ford called and they are going to replace my trans, they found it via the vibration/sound unit they had it connected to the truck for a few days while they drove it moving clips till they pinned it down. I hope this is true and correct. They said they found two different issues. I will wait and see, I will let you know I went & drove a like 2012 yesterday and I was able to get it to do the same thing quickly, without starting a storm I really wonder if Ford received a bad batch of torque converters or transmissions.
rvdb is offline
post #10 of 27 Old 02-27-2013, 08:58 AM Thread Starter
rvdb's Avatar
RTRBURN, I drive like an old man most of the time & the area I live around keeps me in the 35-50 mph zone so it comes around at every run up to speed from a stop.
If I throttle through it you can easily miss it, however at $4.39 a gallon and residential areas I was continuously feeling it which is why I am here. If it goes "through the truck"? it might be similar. Good luck
rvdb is offline
Tags
driveline , harmonic vibration , vibration
