2011 6.7L KR gasping, shaking and knocking - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
 2Likes
post #1 of 23 Old 10-01-2012, 02:51 PM Thread Starter
Not sure if pbruckne is still posting or if any other 6.7L owners are experiencing this, but here is my situation... After driving my 16k mile f250 king ranch around town something started to happen. Once the truck is up to temp and I get it up to speed, anything above and between 35mph and 60mph, I let off the accelerator. Then when trying to maintain speed by lightly pressing down on the accelerator, the truck starts to gasp, shake and a knocking sound comes from what sounds like under the truck. It happened three times in the last 2 weeks. I took it to the dealer and they updated the computer, checked codes (none), pulled the egr valve (clean) and changed the fuel filters. They told me Ford knows about it and is working on a fix but couldn't tell me what it was. They also told me not to baby the truck and drive it like you stole it. I admit I was used to driving the 5.4L f150 and babied it. So now that I've put a Cetane booster in this tank of fuel and drive it a little harder. The symtoms have not come back. Has anyone experienced this and found a fix. Or can pbruckne or someone else from Ford provide some insight? Thx Greg
gsmith1687 is offline
post #2 of 23 Old 10-01-2012, 06:50 PM
Had the same problem yesterday. It sounded like the engine was going to come apart. My F250 is currently at the dealer. They ran codes and it came back misfiring cylinder. They determined it was a bad injector. They had to order the injector. Should be in tomorrow. Hope this helps!
Blu
BluOval is offline
post #3 of 23 Old 10-10-2012, 05:33 PM
My 2012 is doing the same thing. Dealer here in Salt Lake act as if they never heard or seen this.
CAT MECH is offline
post #4 of 23 Old 10-11-2012, 09:32 PM
Welcome to my world! Dealer has no clue what it is........
Heritage is offline
post #5 of 23 Old 10-18-2012, 02:37 PM
If you are at elevation and under load good luck with a fix. I have an early build 2011 that I just won a lemon law case on for this same issue. It is a known issue with the exhaust system under high heat and at elevation that they have been working on a fix for since late last year. It almost always happens right after the "cleaning exhaust filter" warning. My truck was in for 10 repair attempts and out of service for 81 days over the last 16 months. Problem is 90% plus of Ford consumers are at low elevation so the problem is not getting much attention. I hate to hear this is going on with the 2012 builds because the arbitrator awarded me a replacement so maybe my problems are not over yet!
bradzf1 is offline
post #6 of 23 Old 04-07-2013, 05:53 PM
My 12 does something similar, less than 6k miles. Runs very well when the engine is cold, starts pinging and rattling under light acceleration after the temp gage moves. Dealer says all is normal, if there was a problem the truck would know. Got to love that.
I wonder if it is a VCV issue as it appears the truck starts and runs for a bit under PCV mode until some unknown time and temperature is achieved, then changes to VCV mode. No change with or without cetane booster.
Mc907 is offline
post #7 of 23 Old 04-24-2013, 08:50 PM
Quoted: 2 Post(s)
Anyone get it fixed?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #8 of 23 Old 04-26-2013, 07:21 PM
I have had this issue for over a year now. The dealership finally put a recorder in my truck and it came back that there was a problem with the regen. When the the regen kicked in at speeds around 45 mph the truck would begin to shake so bad that the truck almost threw me off the road. Supposedly engineering at Ford is working on a fix, but that has not materialized yet. Today a regional customer service manager offered me a thousand dollars and said that would solve the problem. When I asked her how that solves the problem, as I am left with a 60k truck that does not work properly, her response was will this is the best we can do.
hamigula is offline
post #9 of 23 Old 04-27-2013, 03:29 PM
ODH
wreedPS
Most if not all of the posters on this thread probably didn't own a 6.7 to start with and there only problem was having nothing meaningful to do with their time. Check out the poster's info; first or second post, disappeared from the forum, no info on their truck that could be checked out. It would be nice if the moderators on this forum would try to minimize this type of posting by checking IP addresses, as several of the posters are probably the same person. Or another idea would be to ask a suspicious poster for the VIN number of the truck and if they would not supply that to the moderator by email, remove their post. I am not saying that all first time posters are trolls as they may never have had a reason to post until they experienced a problem. Another forum that has an active Ford rep participating has much less of this problem, as in most cases he asks for additional info which a troll can not supply
ODH is offline
post #10 of 23 Old 04-27-2013, 07:10 PM
Quoted: 2 Post(s)
Wow got it.
wreedPS is offline
