Annoying squeaking - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 3 Old 06-04-2012, 03:38 PM Thread Starter
CM250's Avatar
Annoying squeaking
I just got finished putting on a 6" 4 link skyjacker on my 2012 f250. Did it my self and everything seems to be working fine. Until today I put my fox dual steering stabilizer on and now it squeaks when turning left and right. Don't know if the shocks are stiff and have to work in a little, meanin they are putting pressure on a bushing in the steering right now. Want to make sure it's not putting pressure on steering pump and that's what's squeaking. Hard to tell where it's coming from. Anybody have any experience with this situation after adding stabilizer? Also kept factory upper stabilizer.
CM250 is offline
post #2 of 3 Old 07-20-2012, 06:23 AM
Pop55's Avatar
Annoying Squeak
Had thi happen on my 11f-250 after 4"lift it was the track bar bracket tightened it up and everything's good. Might want to double check your pitman arm as well.
Pop55 is offline
post #3 of 3 Old 08-03-2012, 01:18 PM Thread Starter
CM250's Avatar
Thanks man, I will check that bracket and pitman arm again this weekend.
2012 F-250 Lariat
5" Diamond Eye Straight
H&S Mini Maxx
S&B CAI
SkyJacker 6" 4-Link
Bilstein Shocks
Dual Fox Steering Stabilzer
37x13.50x20 Toyo Open Country MT
20x10 XD Strike -24mm offset
AMP Research Power Steps
CM250 is offline
Tags
dual stabilize , lift 37s , squeak
