6.7 boost problem - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 7 Old 05-11-2012, 09:09 PM Thread Starter
6.7 boost problem
Driving down the road with the cruise on at 110km the boost gauge fluctuates up and down between 10 psi and somewhere around 2psi. There is no change in rpm. I took the truck to the dealer as soon as I got it to town, they scanned it and tell me nothing is wrong no engine codes or lights. The truck still seems to have power which makes me think the gauge might have crapped out. Does anyone have any idea what is going on here? since the dealer dosent seem to be able to help.
mitchstefan is offline
post #2 of 7 Old 05-12-2012, 06:41 AM
as you go up or down hills the boost will change and the rpms dont have too
Boost varies with the load put on the engine
2011 F260 6.7 CC 4x4 LB
gsxr1300 is offline
post #3 of 7 Old 05-12-2012, 09:25 AM Thread Starter
This is happening on flat ground no hills. And the boost is bouncing up and down with no load
post #4 of 7 Old 05-12-2012, 09:36 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 275 Post(s)
my 6.4 used to do this when it was in Regen mode?
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #5 of 7 Old 05-12-2012, 12:41 PM
Hawkeye Diesel's Avatar
My 11 does this from time to time as well. Not always, but I've noticed it more often here the last few weeks.
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #6 of 7 Old 05-15-2012, 05:05 PM
StonemanQA's Avatar
Was your cruise control on? I have heard it regulates speed with adjusting boost over throttle position. Boost will fluctuate with wind and slight grade changes. Mine will do this more doing regen or a stiff head wind.
2011 job2 F-250 XLT CC LWB SRW 4x4
6.7 PS! Awesome engine
Tuxedo Black, Steel interior
E-Locker, 3.55's, sway, stability control
Trailer package, Valley WDH,
18" rims
20 mpg mixed driving empty
14 mpg towing new holland skid loader
39525 mile
S and still ticking!
Traded:
1996 F-350 XLT CC LWB SRW 4x4
7.3, 4.10's
Silver on Black with steel interior
257000 miles
Billet torque converter @ 127000 miles with upgraded
Shift controller
15 mpg downhill with a tail wind empty.
StonemanQA is offline
post #7 of 7 Old 05-15-2012, 05:51 PM
Bryce18's Avatar
Quoted: 19 Post(s)
like said above, the first question is, did you have the cruise on?
If so, this is the "turbo surge" many of people have noticed. It is common on the 6.4s and 6.7s
It was explained to me as the pcm trying to match torque to the speed, when the cruise control is on. (therefore increasing and decreasing turbo boost) My 6.7 did this every once in awhile and drove me crazy. if you kick off the cruise control it should stop, drive a few miles and set the cruise again. this worked for mine.
Although i tuned with H&S at 8,000 miles and my truck hasnt had the turbo surge even once since then.
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
Tags
6.7 turbo , 6.7 turbo problems , boost issues , boost psi
